- Dec 20, 2005
Have you ever used a Forrester?, and if so, how does the rogue compare?
Well, the edge neither rolled nor chipped and the tip held despite its acuteness.
... the elegance of the full convex grind.
I don't know what you mean or estimate the dynamic balance?
That of course depends on the 7" knife and the 10" knife.
I would expect chopping ability at least quadratic in length.
It also helps reducing binding.
True, but for a machine a flat is much easier than a curve. To me the appeal is more in how the light reflects of the blade. One blade that is ground like the Rogue's the reflection are constantly changing curves, on a flat they are "boring" straight lines. But obviously that is just personal appeal. But I understand what you mean, your appreciation goes up once you understand the difficulties and challenges involved.I never did find it overly appealing, likely because I find flats more difficult to grind. It is easy to take a knife and turn it into a full convex grind, just put it in the slack region
Very true, I have experienced the same on this very Cherry when it first came down. I could not make any headway on the many, many thin (0.5-1") branches with a hatchet since they would simply bend away, which made me looking for a longer blade for yard work. After reprofiling the RD9 fills that role very well (though a Golok might have been better still) and takes those branches clean with one swipe.It depends on what you are chopping either really light material or really rigid material as you need corrospondingly maximum speed (tip cuts) or maximum inertia (cuts near the static balance point).
Is it related to the balance point of the knife?
