- Jun 10, 2003
One advantage of O-1 is that it can be hardened from as low as 1450F.Since you are not forging the material the structure will be sheroidize annealed when you start. This is too soft for my tastes.I would first normalize it which would hive you a stronger pearlite structure , then differentially harden - pearlite spine, martensite edge....The second photo is better but why hold it in your hand ? First make sure the two edges [one is usually enough] are in the same plane, tape them together then hold them upright on a table with a C-clamp. Then you can pay attention to the photography, use a tripod too, it's easier...When you want to photo fracture surfaces be very careful with the material - don't touch it with your fingers or scratch it.If you have to remove oil use just a solvent, if necessary you could use a soft brush with the solvent.
