- Feb 8, 2006
Today I had an employee break off a 1/32" endmill in a titanium ring. This ring gets holes all over the surface, like Swiss Cheese. It was just about flush to the surface, so I couldn't get ahold of it. I tried soaking it in acid knowing that the titanium wouldn't react much and the endmill should, but I started to run out of time, and it wasn't eating the endmill at all. Thinking about it now, it was a carbide endmill, so the acid wouldn't have done it, as it's pretty inert. I then realized that I could blast it with my laser welder if the power was high and the beam was tight. It blasted a hole right through it, and I was able to mill the hole cleanly afterward and ship the ring.
Is there something else that could have worked in such a situation? I suppose I might have been able to crush the endmill, but that would risk ruining the surrounding metal. Running another mill behind it would just tear up another cutter. I suppose the same issue would happen with taps. Is there a good way, short of EDM to get them out?
