I decided to see how the Green Beret dug into wood, so I gave a light stab into a plank of wood and tilted the knife to the side to tear out a small piece of wood. I heard a tiny "snap" sound and when I looked at the tip....it had snaped right off the end of the knife like a brittle piece of glass. Looking at the knife from the side, the horizontal length of the break line is about 1/32" long. Is this my fault for sharpening the knife too fine at the tip? I suspect it might be, but I didn't know you were supposed blunt the tip so it wouldn't break off. I gave a few more hard stabs out of frustrated curiosety and dug the wood out to the side again to see if it would break further, and it didn't as far as I can see. So...what to do? When I sharpened the knife I only went 17deg per side from the back of the blade all the way up to the tip. The bevel didn't look very thin or fragile at all. It looked like a solid grind, not too far from the original grind, except for the fact that the edge was shallow enough to be sharpened with the Sharpmaker along the whole length of the blade. So...does it sound like I just noobed it up? Or should the tip have been stronger than this.
