- Jul 4, 2010
Sorry I couldn't fix it so deleted.The link doesn't seem to work for me
I purchased it December of 2024 so that time frame may coincide. I will reach out to AKS to see what they say.A friend I work with personally ordered “aeb-l” from aks some time last year or the year before that was not hardening correctly and cracking without him even straightening and I believe we figured out it may have been A2 I think it was the same 1/16” thickness, they eventually sent him a refund for the steel, I’d suggest reaching out and see if they can track that bar just to confirm it is aebl and rule that out of the equation. I plate quench and straighten 1/16” stock quite regularly and haven’t had any issues with cracking either aebl or nitro-vJTknives I’m not sure if you already do this but on identical profiles I clamp them as a stack between two straight pieces of angle iron and leave them clamped for cryo and both temper cycles before removing the clamps and that has drastically reduced warping especially on thinner stock.
Definitely didn't get that result! Do you know what hardness you got?Maybe this will work. This is a santoku 2" at the heel and .072 thick AEB-L. Full flat grind to .005 bte. Heat treat by Boz.
Asked for 61-62Do you know what hardness you got?
Yeah we clamp them to steel when we have room. When doing 20 to 30 blades at a time it gets real hard as that’s a ton of clamps and freezer space for cryo.A friend I work with personally ordered “aeb-l” from aks some time last year or the year before that was not hardening correctly and cracking without him even straightening and I believe we figured out it may have been A2 I think it was the same 1/16” thickness, they eventually sent him a refund for the steel, I’d suggest reaching out and see if they can track that bar just to confirm it is aebl and rule that out of the equation. I plate quench and straighten 1/16” stock quite regularly and haven’t had any issues with cracking either aebl or nitro-vJTknives I’m not sure if you already do this but on identical profiles I clamp them as a stack between two straight pieces of angle iron and leave them clamped for cryo and both temper cycles before removing the clamps and that has drastically reduced warping especially on thinner stock.
I’m removing this comment as I just talked to AKS and this is not what happened. As I have said here and to all my customers “AKS is the best from my experience”.Thanks Josh. I recalled that situation but didn't want to mention the incident without further discussion. That is why my first suggestion on why it cracked and broke was the steel may be wrong. I agree, contact AKS.
What are your thoughts on the video that Jesse posted of a thin AEB-L knife with a similar requested harness and flexes almost 90 degrees? I assumed a kitchen knife wouldn't withstand that level of abuse but I never dare test my knives like that.Could that be what’s causing the weird pattern I got in 2 separate orders? If it is A2 then it would be massively over heated if treated as AEBL.
Good to hear, I know there was an issue with one bar/sheet in the past that my friend had and it was taken care of and it definitely had an off heat treating response. Figured with this looking like a similar time period it was worth checking.I just talked to eyeeatingfish. This situation is odd. We rarely hear of anyone having cracking issues with AEB-L, especially considering how tough the steel is.
In response to Josh's question about the steel being mislabeled, this steel is definitely AEB-L. We have strict procedures that are followed in the shop to ensure steel is labeled properly. If this steel had been something like A2, it would acted much differently during heat treat.
I also know the batch of steel this came from. This AEB-L had been set aside out in the shop because it got some gouges on the surface and couldn't be sold with our typical AEB-L due to it's surface finish. We put it on clearance as "blemished" with a significant discount knowing that it would require more work to get out the scratches.
I suspect stress risers may have been the problem, especially considering this steel had surface gouges and scratches. If the gouges were not removed prior to heat treating, they potentially could have caused additional stress that resulted in cracks.
- Jessica Walker
Depends on the geometry. Remember kitchen knife covers a lot of design spaceI assumed a kitchen knife wouldn't withstand that level of abuse but I never dare test my knives like that.
I have some leftover pieces in my recycle bin from that bar. I will try a few tests on it including an acid dip to see if it behaves like stainless and bend it to see if it behaves like annealed steel. I could try other things if there are any suggestions.Could this be something due to the initial condition? I didn't see a reference to annealing or normalisation
Josh, the "issue" you are referring to was not the same timeframe. The last time you and I talked about it, you brought it up in Nov of 2023 and said your friend had it happen recently. I still have questions regarding that situation, but I don't think it's worthwhile playing he said/she said.Good to hear, I know there was an issue with one bar/sheet in the past that my friend had and it was taken care of and it definitely had an off heat treating response. Figured with this looking like a similar time period it was worth checking.
Jessica, Thanks for posting that info. That certainly seems to remove any doubt about it being AEB-L. As you suggested, it is now most likely a strress riser issue. Maybe from the gouges, maybe from the grinding, maybe from some other source we haven't considered. At this point we may never know.
I will point out to anyone reading this thread that Alpha Knife Supply , its founder Chuck Bybee (RIP), Jessica, and the crew, all have built a great resource business for knifemakers. They are a quality supplier and good people. Buying from AKS is a reliable and fast process.
Sorry Jessica I wasn’t intending to create an issue and you all took care of the steel which in my mind resolved that problem. I couldn’t rember the exact date but knew it was somewhat recent and some of the cracking reminded me of that situation so figured would be worth double checking. Again didn’t mean for it to be a negative conversation but just ruling out that it wasn’t from a similar batch of steel which it looks like that’s not the case. Hope you all are doing wellJosh, the "issue" you are referring to was not the same timeframe. The last time you and I talked about it, you brought it up in Nov of 2023 and said your friend had it happen recently. I still have questions regarding that situation, but I don't think it's worthwhile playing he said/she said.
The AEB-L eyeeatingfish purchased was in December of 2024.
Thank you for your comments Stacy, I really appreciate it.
- Jessica Walker
