- Dec 13, 2005
so i plated my infi with bronze..... then did a slight liver of sulfur patina..... i like it..... oh hey all of you guys..... i have been busy as hell...
Looks very unique!! Sweet!!
unique is a good code word for 'why would you do that?',,,lol
no one has even asked the most important question...... 'how did you plate micarta....... ???????????
and dont ask....cause its a huge secret
NOT AT ALL!!! Not what I meant!unique is a good code word for 'why would you do that?',,,lol
A better question is why plate the micarta?
Actually, Bronze plated blades with Black G-10 would look frappin' sweeet!!A better question is why plate the micarta?
good questions.... i deveoped this product.... its real bronze, also doing it in pewter brass and copper...... no heat involved...... and aheres to just about anything..... including plastics...... also has increased flexibility.....I guess my question would be "how does the bronze react given that its base adhesive surface is a powder coat?" - unless its adhered to the metal itself...
does it tend to dent with high malleability (which I would think is inherent in bronze), does it dent "too much", quickly giving way to the darker powder coat leaving an easily scratched area...
cause if bronze can be applied to a blade at less then 900 degree's (or below 350 degree's for the micarta (or quickly enough in its cooling process that it doesn't effect the micarta regardless of starting temperature)) so that it doesn't damage the overall blade - theoretically you would have a very impressive coating as long as its general malleability and adhesion was strong enough to resist damage.
dan kosters "copper top" black powder coat that he worked out with a local powder coat guy is another curious "if its real copper (and I think it is), does it add noticable durability to the powder coat?"
also, does it tend to adhere/penetrate into pores and scratches in the blades surface?
very interesting....
16 of themwow
patents generally suck to get, and awesome if you can get them on your process![]()
