Brous Blades, Bionic 2.0, Flipper, D-2 Blackout finished Blade, Blue Handle, $178.95
Feedback: +1 / =0 / -0
(32) Brous Blade models in stock!
Suggested Retail: $264.95 Our Price: $178.95 You Save: $86.00
Free USA shipping on all orders over $99.00
http://www.knifeworks.com/brousblad...koutfinishedbladebluehandle.aspx#.VUYNOxvwvIU
The goal for the Bionic was to create a small, light weight, easy to carry and affordable everyday carry folder.
The hollow ground D2 blade rides on our proprietary ball bearing pivot system making the deployment quick and easy.
The CNC machined handle scales are made from air craft grade 6061 Aluminum and
feature a stainless steel liner inlay which provides a strong and sturdy lock up for a lifetime.
The Bionic flipper can be deployed 2 ways, using the flipper tang or using the manual opening option with the groove cut out above the grind.
Brous Blades has brutality tested this flipper for the past 6 months and has been repetitively reliable.
Jason Brous has made the Bionic 2.0 his first choice for an everyday carry.
The Bionic comes with a Certificate of Authenticity card signed by Knifemaker, Jason Brous and is dated.
The Bionic also comes with a Brous Blades Custom Case made of hard nylon with a matte black finish and has foam inserts for protection.
SPECIFICATIONS:
Overall Length: 7"
Blade Length: 3"
Blade Thickness: 1/8"
Blade Material: D2 Tool Steel
Blade Finish: Black Cerakote
Blade Style: Drop Point?
Blade Edge: Plain
Blade Grind: Hollow
Handle Material: Blue Anodized 6061 Aluminum ?
Lock Mechanism: Linerlock
Liner Material: Stainless
Opener: Flipper
Pocket Clip: Reversible??
Closed Length: 4"
Weight: 2.71 oz.
Made in the USA
