- Sep 20, 2014
Be one of the first to get your hands on another limited edition knife from Brous Blades. This is the SSF G10, that comes in many different blade options. This makes a perfect EDC to use and abuse, or sit on the shelf. Either way, it is a great deal for outstanding utility. Enjoy! (SHIPS FREE)
SSF Satin $199: http://btacblades.com/collections/brous-blades/products/brous-blades-ssf-g10-satin-blade
SSF Stonewash $219: http://btacblades.com/collections/brous-blades/products/copy-of-brous-blades-ssf-g10-satin-blade
SSF Blackout $229: http://btacblades.com/collections/brous-blades/products/brous-blades-ssf-g10-blackout-blade
SSF Acid Stonewash $239 *1 left: http://btacblades.com/collections/brous-blades/products/brous-blades-ssf-g10-acid-stonewash-blade
The Silent Soldier Flipper - G10 Edition features a D2 tool steel blade with a high utility, Wharncliffe style profile. The double swedge features a variable grind tapering down to a laser precise tip. The spine has aggressive thumb jimping and a 7/8" finger hole in the blade for ultimate control with various grip styles. The pivot utilizes a ball bearing system and heat treated pivot and stop pin. The handle employs skeletonized stainless steel liners, black G10 scales along with a bead blast finished stainless steel back spacer and pocket clip. The SSF's features and shape provide outstanding comfort and flexibility in a wide variety of roles. The answer to the EDC question.
SPECIFICATIONS:
Overall Length: 6.375"
Blade Length: 2.5" (Blade Tip to Handle)
Cutting Edge: 2.25"
Blade Thickness: 3/16"
Blade Material: D2
Liner Material: Stainless
Handle Material: Black G10
Handle Thickness: 5/8"
Closed Length: 3.65"
Weight: 4.2 oz.
SPECIFICATIONS:
Cutting Edge: 2.25"
Blade Material: D2
Weight: 4.2 oz.
