Brous Blades SSF G10
Feedback: +2 / =0 / -0
Be one of the first to get your hands on another limited edition knife from Brous Blades. This is the SSF G10, that comes in many different blade options. This makes a perfect EDC to use and abuse, or sit on the shelf. Either way, it is a great deal for outstanding utility. Enjoy!
SSF Satin $199: http://btacblades.com/products/brous-blades-ssf-g10-satin-blade
SSF Stonewash $219: http://btacblades.com/products/copy-of-brous-blades-ssf-g10-satin-blade
SSF Blackout $229: http://btacblades.com/products/brous-blades-ssf-g10-blackout-blade
SSF Acid Stonewash $239: http://btacblades.com/products/brous-blades-ssf-g10-acid-stonewash-blade
The Silent Soldier Flipper - G10 Edition features a D2 tool steel blade with a high utility, Wharncliffe style profile. The double swedge features a variable grind tapering down to a laser precise tip. The spine has aggressive thumb jimping and a 7/8" finger hole in the blade for ultimate control with various grip styles. The pivot utilizes a ball bearing system and heat treated pivot and stop pin. The handle employs skeletonized stainless steel liners, black G10 scales along with a bead blast finished stainless steel back spacer and pocket clip. The SSF's features and shape provide outstanding comfort and flexibility in a wide variety of roles. The answer to the EDC question.
SPECIFICATIONS:
Overall Length: 6.375"
Blade Length: 2.5" (Blade Tip to Handle)
Cutting Edge: 2.25"
Blade Thickness: 3/16"
Blade Material: D2
Liner Material: Stainless
Handle Material: Black G10
Handle Thickness: 5/8"
Closed Length: 3.65"
Weight: 4.2 oz.
