- Dec 19, 2002
Brous Blades, The Enforcer, Folding Karambit, 2.5 in. Satin Blade, Black G-10 Handle
Suggested Retail: $447.00 Our Price: $318.95 You Save: $128.05
http://www.knifeworks.com/brousblad...insatinbladeblackg-10handle.aspx#.VVyTlRvJDIV
The Enforcer is new for 2015 and is the first folding Karambit for Brous Blades.
The Enforcer features 3D-machined black G10 scales.
The aggressively shaped re-curve blade is made from D2 tool steel and has a satin finish.
The handle has been carefully designed to fit your hand perfectly for standard or reverse grips.
The one-inch finger hole works well for any size hands.
The Enforcer has a full G10 backspacer with a raised gear pattern for maximum grip.
The top flipper design gives this knife one of the fastest and strongest actions ever made by Brous Blades.
The specially designed liners are skeletonized to reduce weight without compromising strength.
The Enforcer utilizes the proprietary Brous Bearing System for a smooth and quick deployment.
The pocket clip is right hand carry only and leaves the finger hole exposed for quick access.
The Enforcer comes with a Certificate of Authenticity card signed by Knifemaker, Jason Brous and is dated.
The Enforcer also comes with a Brous Blades Custom Case made of hard nylon with a matte black finish and has foam inserts for protection.
SPECIFICATIONS:
Overall Length: 8"
Blade Length: 2.5"
Blade Thickness: 3/16"
Blade Material: D2
Blade Finish: Satin
Blade Style: Hawkbill
Liner Material: Stainless
Handle Material: Black G10
Handle Thickness: 5/8"
Lock Mechanism: Linerlock
Closed Length: 5.25"
Weight: 6.6 oz.
Made in the USA
SPECIFICATIONS:
Overall Length: 8"
Blade Length: 2.5"
Blade Material: D2
Blade Finish: Satin
Weight: 6.6 oz.
Made in the USA
