Brownell's Gun Kote
Don't use it! I have it on a few of my rifles and it works great...bought some for my knives and it is crap. Asked my gunsmith what gives? His answer was he bought it in bulk...NOT the spray can stuff. The formulation of the product in the spray can is different than in the quarts or gallons or however they sell it in bulk. He must have been right, as the difference is very apparent!
I bead blasted my blades and degreased with acetone...spray and bake. Later on it pealed off easily Same with a sand blasted blade. The stuff in bulk is fine though....
I have used it and not had any trouble with it. They also offer a bake on enamel coating. ( That will stick and then peel off)
I've duracoated a few knives with decent success.
So far I haven't really abused one after coating though. The key in general is to make sure these coatings get a good surface to bond to, then cure them properly.
There is certainly an art to it, just like the rest of the process.
I do have to agree that the kind you apply with your own sprayer work much better. I use an airbrush generally but have used larger guns for non knife stuff and the key is even layers and following instructions carefully. If they say thin layers and let it flash off but not sit more than ten minutes between coats, then they really mean it. In the case of duracoat, you can almost spray one side, flip, spray, flip back, look it over for any issues, spray another layer, flip, spray, leave to cure. You don't need super thin coats, and with an hvlp gun you actually get a very good result with just two fairly heavy coats. The only reason for thinner ones is if it's a tight tolerance part and you want to just build up enough to do the job but without significantly increasing dimensions.
