Hello everyone,
RL:
The Brownie pop is not an inertia opening of the blade as suggested. Nice guess though. I'm not a self professed knife fighting expert. I do train LE and civilians as the adjunct instructor at S+W however. The FBI DT instructor has taken what he got from three days at S+W and put the techniques to use for his agents he is assigned to train in NYC.
I have also trained PD's, swat officers in private settings as well as civilan classes. That doesn't make me a knife fighting expert, it only means I have the ability to impart certain knowledge of the defensive blades which has been gleened from Master at Arms James Keating and the riddles I have attended.
It does wear the knife prematurely as another sugests however and have had to send an Elishewitz back for repair after several years of performing this action type of openings.
The people who have been shown the technique do find it much faster than other forms of opening the blades, though it won't work on smaller blades like the delicas. The blade needs some mass to it.
With the technique, the blade opens immediately upon the knife clearing the pocket. No wasted inertial motions are necessary.
I have privately sent instructions to several forumites relative the technique on the High Road forum and all agree it's the fastest at getting the blades into play from clipped to the pockets on responses received.
Mine are out and open in sub one second times starting from hand on the knife clipped to the pocket. Basically if you touch the knife at the ocket it is opened and in play immediatetly. It requires no fine motor skills which can fall apart in "startle mode".
The name for the technique I developed came from James Keating himself at the first Riddle I attended way back when he saw the technique I had developed. Before that, it was just the way I had developed over the years opening the folding knives I carried.
I actually showed him with two at once from both sides when I was requesting some double knife drills. I was able to produce them that way but did not know what to do with them once they were out. He was quite surprised at the speed and lack of movement to open that way and decided to name the technique [ one he had not seen before ].
Garageboy: Doubt you'll find it on Google. It is not anything thats registered under that name. It's something I developed for myself years ago that happens to be extremely fast.
You might say, it gives you an "edge" against the opponent when in startle mode at the outset of an altercation.
So there is the history behind the technique and how it came to be named. It will not be disseminated enmasse over the forums.
Brownie
