Buck 110 Advice Please
I bought a Buck 110 from Wal-Mart for 27 dollars and used it to snap cut thorn branches off my hiking trails. It very quickly developed blade play, side to side and vertical. I've started using a Kershaw Storm frame-lock now and it's done 10x the work as the Buck and it's still as tight as new. The Kershaw wasn't but a few more dollars.
Maybe all Buck 110's won't do this but mine did and I don't use high dollar blades for this daily chore.
I have seen broken blade tips on every knife imagineable - including 110s. I've never seen one with much play at all. They are excellent cutting tools. Even fb knives make poor prybars, of course. Buck's warranty will take care of that - send it back to ID! You can get their address on their site.
Stainz
One disadvandage of the 110 is the pinned pivot construction.
I've seen many 110's with terrible side play simply due to the pivot pin pulling loose. It is nothing new and not limited to the 110.
maybe the high quality feel and the fact that is heavy made some users think of it as a fixed blade, and that it can stand a lot of abuse...just an idea...
buck stands behind their products, i'd contact them and see about a repair or replacement. maybe you got a bad one. one thing i can't stand is sloppy blade fit.
I have not owned a buck 110 and was thinking of getting one. What are the liners and washers beside the blade made of? whats the wood used in the standard 110?
Liners are brass on a stock model bought in a store.
There is a small washer inside the blade that the pivot pin goes through, that's either brass or bronze??
Wood on a stock version is laminated Obeeche wood.
Its a classic. In fact its interduction created a revolution in the in the knife industry. Its hard to beat as it may just be the best knife design ever marketed to the mass public.
It is big and heavy but I like that, but if that is a concern try the 112 or the look to the 500 series (the 500 Duke is a personal favorite of mine, its been discontinued but available on EBAY).
Also, I believe you can't call yourself a "Knife Guy" unless you own a least one 110. If you want to be real sporty go with the 110 in a premium steel. Those are available through Bass Pro Shop (154cm), Cabelas (S30V), and the Bucks Custom Shop (S30V and some other nicer 420HCs).
Go forth a get the nicest 110 your budget will allow. You won't be disappointed and if you don't loose it, you'll have it 40 years from now and it'll still be a solid capable knife. Just my 2 cents worth.
Everything he said x2!!
An argument for the Buck 110:
I suppose it depends upon how you use your knife....
If you are the type that is constantly using your knife all day long, making small cuts (string, paper, etc...) numerous times per hour, then a pocket-clip one-hand folder (or a small fixed-blade, or even scissors) makes better sense than a Buck 110.
Or if you're the type who wants a knife that can be deployed in a blink of an eye for fighting off attackers (real or imagined) then perhaps the Buck 110 isn't for you.
And if you wear clothing that does not accomodate a belt and a pouch (skirt, hospital scrubs, bikini, thong, swim trunks, whatever...) then you might want a light-weight pocket-clip folder.
But if you want one of the best performing folding knives ever created, then the Buck 110 is what you're looking for.
Of all of my folders (and I have quite a few) the Buck 110 is the best design for actual long-term serious cutting:
The handle is as close to perfect as I've found in a folder: neither too fat nor too thin, smooth and non-abrasive to the hand, yet secure and comfortable, even after hours of cutting.
The blade is simply fantastic for what the knife was designed to do: cut things!
The high hollow-grind makes the 110 just sail through material.
And the ultra fine point is perfect for fine detail work.
It's not a knife designed to pry and probe, that's for sure....it's designed for cutting and piercing....as a knife should be.
And when the knife is opened, the balance is especially nice.
It is a knife of substance and heft, with some weight behind it.
And that weight actually helps you make cuts without compromising control....the same way that a nicely weighted putter performs in golf, or a perfectly weighted bat performs in baseball.
And what can one say about the lock?
The lock-back design is strong and reliable and has proven itself millions of times again and again for over forty years, and has been used by hundreds (if not thousands) of custom and production knife makers all around the globe.
The lock has proven itself to be easy to operate, easy to maintain, very reliable, and strong and secure even after years of service.
There are many folks using lock-back folders that are well over thirty years old and still going strong.
And the Buck 110 is beautiful too!
The basic stock 110 looks nice enough, but the Cabelas Alaskan Guide Buck 110 and the BassPro Shope Buck 110 really step it up a notch.
And then there are the options available from Buck's own Custom Shoppe....simply fantastic!!!
Remember, no one is ever ashamed to be seen with a Buck 110 on their side. :)
For $30 you get a tank of a knife.
For ~$100 you can get a very nice customized Buck with nicer scales and better steel.
Yep, a basic 110 is hard to beat for utility. And... that 'Custom Shop' - wow - even I, a retired instructor, could afford my trio over the last nearly a year now:
Stainz
You just can't go wrong with a Buck 110. I have a drawer full of Spyderco knives, but my 110 goes everywhere with me. The 110 is my all time favorite.
i bought a 112 its the same as 110 but a tad smaller . more pocket friendly . i didnt expect much as it didnt cost me much from e-bay ,,, but when it arrived :eek: wow this is built ,,,, like a rolls royce ,, still blows me away everytime i look at it .. prolly the best folding hunter ever made . try one . puts other makes to shame .
oh yeah just one more thing .looking at pics of them just dont do it .. just wait till you get one in yer hand then you will know you have a knife .
