Buck 110 or Benchmade Big Summit Lake
I want to get a classic looking folder for the cottage and as a gents folder as well. I am torn between the two but leaning Benchmade because I love Benchmade and I like the S30V on the Benchmade rather than the 420HC on the Buck.
Tell me your experiences with either of them and why you like them.
Thanks
I had a Benchmade Small Summit Lake. Excellent knife couldn't find anything wrong with it. Reason why I sold it (and most of my other Hunt series) was because of the Dymondwood. It simply wasn't for me.
What's wrong with the dymondwood? Does it fall apart when it gets wet?
you can get a custom shop made 110 with s30v. just a thought in case you didn't know.
The Buck 110 is one of my favorites , I have a few of them in different variations.
But it is strictly a belt knife, so if you're planning on pocket carry, I'd say the BM has the advantage.
That being said , the regular 110 is pretty inexpensive. I saw one the other day in a big box store for $27 US.
If you need a pocket clip, grab the Summit Lake. I had one for a while, and it's a fine folder.
If you're open to sheath carry on your belt for the 110, then check out the 110 exclusives by Copper & Clad (in s30v) and Silver Knight Blades/SKBlades (in CPM-154). They both also offer their exclusives in a drop point blade profile if you prefer.
Both are bladeforums supporting dealers, btw :thumbup:
Also, know that we CAN install a pocket-clip on a 110... but it won't make it lighter! The 110 has a LOT of heavy brass in there. The Eco-lite version and various Bucklites and bantams can solve the weight issue, but none of them have that classic appeal of the wood+brass 110 and 112. :cool:
also the copper and clad aluminum bolster version of the 110s.
no. it's basically birch wood layers think like plywood, but with some sort of resin or epoxy. making it very very stable and water resistant on absorption. so no water will absorb or warp, etc. there was a post on the buck forum where someone found a 110 in a stream, that had been there a while. the dymondwood looked like new still compared to the rest of the knife.
Wow, that summit lake is the nicest looking benchmade knife I've ever seen, who knew that benchmade could actually make a beautiful knife. I'll probably never own one because, but I never even knew they existed till now.
Now, the buck 110 is one of those knives where once you see it you know weather or not you want one. The fact that you're even considering the buck 110 tells me that you want one, and let me tell you that you've made a good choice.
The 420hc buck uses is awesome, the ergonomics are awesome, the blade geometry and sharpness are awesome, the nice piece of leather it comes with is awesome, and lastly buck as a company is awesome and they will do you right if you have any problems. The standard buck 110 can be had for about 30$ so there's no reason not to own one, but they also have a myriad of options if you want something more and fancier.
A few pics of the knife i would recommend, :)
With S30V blade, nickel silver bolsters & red cherrywood:
With S30V blade, nickel silver bolsters & Indigo Royalwood:
DymondWood® is a highly engineered wood/plastic composite, that has the physical and mechanical properties of high density hardwood, acrylic, polycarbonate plastics and brass.
Here, brightly dyed northern hardwood veneers are combined with engineering grade resins, heat and pressure to create a product that has the best characteristics of each.
DymondWood® is distinguished by its unique strength, durability, dimensional stability, and weather and moisture resistance as compared to regular wood.
I would buy a summit lake, and get a 110 anyways too - they're cheap. I have many of and used to always carry a 110, then I got my summit lake. I actually prefer the small summit lake over the big, but you have to rush to buy one they just got discontinued but some places still have. I bought a few for the future.
Sent from my SM-G900W8 using Tapatalk
I bought the big one and I like it very much. I dont like blades that are smaller than 3.4" so im probably not going to get the small but I may if I change my mind. Thanks
I think the Summit Lakes have a great look to them, though I never owned one. I'm convinced for an EDC knife the Benchmade would be better, just from size and steel. It looks to me like it was made for that.
Back when I was younger I'd carry my Dad's 110 when I was hunting and that thing is a monster when it comes to weight. I remember dropping it in my pants pocket and it felt like a 5lb. dumbbell sitting in there. I personally wouldn't carry one as an EDC, just because I like having my pocket knives in my pocket. It's a workhorse though. That's what it was made to do, work. If you're looking for a no frills knife that'll take just about everything you're gonna throw at it, it seems the 110 was designed just for that.
Benchmade all the way for quality, fit/finish, steel, customer service, etc. The biggest problem with the 110 is it's too big & heavy unless you like to carry a sheath. However, if price is a concern, you can get 3 Wallmart Buck 110s for the price of the Benchmade.
That's awesome. I bought the big one first then tried the small because even for a shorter blade it's wide and has the feel of a bigger one, I used to carry a Buck 501 for years and it was similar lengthwise but just seemed and felt small which is why I started carrying the 110, but it was so bulky and heavy. Benchmade fits the bill perfectly.
Thanks
First off, this is a "go with your heart" or "trust your taste" sort of thing. It's sort of like comparing Dunkin's medium roast to Starbuck's dark roast, or a 64 Mustang to modern Lexus, or a modern IPA to Budweiser, or Wild Turkey 101 to Oban, or... well... you get the idea.
Second, as others have noted, these are belt knives. Or... run a seam half way up your rear pocket and carry the knive there. I despise belt carry. Completely hate it. But I like rear pocket carry with this simple sewing mod. The Buck 110 has become one of my most commonly carried knives because of this. IME, it's simply too big to carry in the front pocket.
Now, about my experience.. I only have the classic 110 so will restrict my comments to that one. It should be noted from the git go that Buck offers S30V and drop point options in their custom shop. As others have noted, Copper and Clad and SK Knives also have several nice 110 variants. The Copper and Clad aluminum bodied 110 is on my to buy list for sure.
The 110 is a very nicely balanced knife. The first thing you notice in your hand is the weight, but it feels incredibly natural. I have XL sized hands and the size of the handle feels great for me. I also hugely prefer the non-finger groove version as it allows my hand to move around easily to any grip I want.
The overall size of the 110 is in that classic do-everything size. It's similar in size to the Mora Companion. It's big enough to handle most large cutting but not so big as to get in the way. It can be easily choked up on if needed.
I have an uneasy relationship with the clip point. It's frail and easy to break the tip compared to drop points. I treat it more gingerly when working in the shop. On the other hand, I admit that the small clip can make some smaller cuts easier and it looks... well... like a 110 is supposed to. I'll get a drop point someday too.
Buck's hollow grind is almost as good as a hollow grind can get. Nice and thin behind the edge but the severe transition of the grind causes it to hang up when slicing things like potatoes. It's a better cutter than slicer. I usually end up flattening my hollow grinds on a stone and I really wish Buck would do a true full flat grind.
My recommendation is that if you're not sure about the decision, get a standard 110. It will set you back only $30 or $40 depending on where you get it. Nothing like living with the knife for a while to see if speaks to you. I will say this... It takes me years sometimes to discover the aspects of a knife and teh 110 has been that way for me. I got my first in 1973 and I still feel like I'm learning some aspects of it. It's given up its beauty to me slowly. Anyway... try the inexpensive one first. It's a heck of a deal and if you fall in love, you can gift the standard one or toss it in the tool box while you put in a order for your dream 110.
Personally, straight up head2head I would get the big summit, withour a doubt,
but.....
A custom 110 in the same price range, now it's a toss up.
A legit Lochsa or Magnolia 110 are also now fair game.
If it were one or the other for edc, I would undoubtedly carry the Benchmade over the Buck due to a number of factors, not least of which is carry convenience. BUT I am also of the opinion that everybody needs a Buck 110. Get one and use it for a weekend camping and then throw it in the glove box. Shoot, this thread has me thinking I'll take a 110 as my only folder next camp trip just because. It is a great folding knife and Buck is :thumbup::thumbup:
