- Apr 12, 2009
Has Buck changed the grind on the 110? All of the Bucks I've owned have had the same basic grind (not counting the thickness near the edge) with pretty pronounced shoulders. I've thinned a few pretty dramatically, including a 112 with a 442 blade and found them better "slicers" through things like apples and potatoes after they were thinned but still nothing compared to a proper flat grind. I know you find flat grinds prone to suction problems though.
One place I find hollow grinds better is with flesh. Better for meat, imo.
Sorry if my description was confusing; might be slanted by my own perception of it, if not technically accurate. Here's how I've viewed it:
Buck's grind on the 110/112 has varied somewhat through the years (since the '70s, anyway). But to my eye, it's always been essentially something like a 'high hollow grind' with a little bit of 'sabre grind' nearer to the spine (about 1/4" wide, above the hollow in the grind). The old 'hollow' in the '70s-vintage blades seemed to be of a smaller radius in the central portion of the blade, leaving a somewhat thicker portion of steel behind the cutting edge, and the flat portion near the spine. The newer blades, maybe mid-80s and later, seem to have a more gradual, thinning taper in the hollow below the 'flat', all the way to the cutting edge; more like most of us would expect to see in a true 'hollow grind' with a very thin slicing edge.
My inclusion of the 'sabre' description of the grind comes from differentiating it from a full-height hollow grind, as is often seen on many of Case's current line, for example. The hollow on their grind extends essentially all the way to the spine of the blade, with little/no 'flat' portion between the hollow and the spine.
David
