Buck 303 Cadet 3 1/4" in sawcut black delrin (USA)
Well made work knife, nothing fancy.
Has three back springs with each blade with its own spring.
The sheepsfoot is on the opposite side to the main clip, and is longer than other stockman sheepfoot blades.
Because of the three back-springs:
The knife is wider, which gives it a more chunky feel in the hand.
The blades are hollow ground, so the blades retain their full thickness the whole spine of the blade. This makes for a thick blade profile.
The thick blades are hollow ground, so again the blades look chunky from a thick spine going quickly to the hollow grind on the narrower blades.
The blades are also thick to use. The blade profile does not allow for thin slicing of a soft substance.
If you like thin flat ground blades, or something thin in your pocket; this is not the knife for you.
A plain jane, well made, worth the money for hard use.
Edit:
Honestly, for the price range, I would suggest a Boker in Carbon and bone.
The Bokers have so much more character to them
Although they might not stand to as hard work as a 4" Buck
Edit:
