- Dec 19, 2006
Mine has been in two different US factories
Buck forgot to spin the center pin on mine and someone affiliated with another manufacturer kindly spun down the pins for me. Here's the after photo.
If you compare the springs and blades on this Victorinox to the Buck 310, you'll see the stock thickness is very thin on the Buck 310.
On the larger 301, the difference in performance between the old full flat grinds and the present saber grinds is more noticeable.
I do prefer the older full flat grind used in the late 80s by Buck and earlier by Camillus and Schrade for Buck. But the present saber ground Buck 301 is also a very nice knife with lots of uses... e.g. good for push cutting through plastic, etc.
The 309 companion probably uses the same blades as the whittler. My whittler is also marked 309. Here's an ad showing the 310 model number.
Do you find any drawbacks with the saber grinds typical on these Bucks? I often hear complaints about the slicing ability of knives that are "too thick behind the edge", and a saber grind is definitely thick (WAY) behind the edge. Thanks for any opinions/experiences anyone is willing to share.
- GT
Buck 309 T, I've carry this in my pocket for years. Great little knife and better than a muskrat at least for me. Hey guys I've got a question?? why is this a 309 and yours are 310's ?? Do I have a mistake here. OK, well I did some investigating and came up with this from a internet site called Worthpoint. Here is the quote "This was a factory error according to Buck, since it's definately a model 310 Whittler. A model 309 is a two-blade knife. The box is clearly marked "310" as well. It was simply a mistake when it was made, so there were very few of these like this. Knife was first un-wrapped for picture only. It is 3 inches closed and has the black delrin saw cut scales. Don't confuse this knife, with the common 303 "Cadet" and the 373 "Trio"."
