allenC said:I have to go against the herd on this one.
I've never been very impressed with Buck's 420HC.
In my experience, it does'nt get that sharp, and it does'nt hold an edge nearly as well as AUS-8, 440C, 154CM, ATS-34, ATS-55, S30V, VG-10, GIN-1, or even H-1.
Allen.
m_calingo said:If I'm not mistaken, the earlier Buck 110's used 440C, and some time later they switched to 420HC.
Buck does 420 OK, don't they?
I got my "first knife" here:it's a Bucklite the blade is marked 426^ so I've no idea what it is...I'm thinking 425 steel.m_calingo said:If I'm not mistaken, the earlier Buck 110's used 440C, and some time later they switched to 420HC.
Ilovetoolsteel said:I gotta agree with Allen here. I just tested a brand new buck 110 against my old from the 1980's 110 and it didn't hold the edge half way through the task.
I was pruning some trees in my yard and I had 2 6' pieces of chinese elm about 2" in diameter at the base tapering to about 1" I stripped the bark off of both first with my old 110 which I hadn't sharpened in a while and then with my friends new on sale at walmart 110. My old 110 was still using sharp when I was done. The new 110 had a flat spot along the area getting the most use. You could feel how the edge had rolled over. It only stripped about half the stick. We resharpened the new 110 on my lansky with a steeper angle and it stripped the rest of the stick but the edge looked and felt the same as after the first try.
Buck has sold out their customers.
Lavan said:Just reading a post "across the street" sorta knocking 420. I just ordered a Buck Bowie in 420HC. I thought Buck did purdy good with 420. Don't they?
Tok said:I've a Buck 371 lately, which has 440C. Its edges do hold very well. I wish Buck will make some 110 with 440C. I will be happy enough to get one.
