Buck Hartsook Neck Knife Impressions
Vivi
BANNED
Thanks to A2D2, I recently received a Buck Hartsook Neck Knife. Here's the Buck product page: http://www.buckknives.com/catalog/detail/564/234
This is a unique knife for me. It's my first Buck fixed blade, my only coated knife, my only neck knife, my first fixed blade without scales and my only S30V knife. When I first saw it I was attracted to the knife, but I wasn't completely sure why. I didn't see it as practical compared to a Victorinox Classic, I didn't expect it to become my sole EDC, and I didn't see what use it would get if I carried it along with my typical EDC folder. *shrug*
The knife has been growing on me though. The first things I noticed about it were its slimness and light weight. It's very easy to carry in the front pocket, watch pocket, in the wallet, behind the wallet, front shirt pocket, tucked away in a belt etc. This seems to be one of its best points, how easy it can be to carry. For instance around the house I'll often wear athletic shorts rather than jeans and I've just been tucking it in my waistband on my right hip. I haven't tried carrying it around my neck because I know I would not personally find that comfortable (I hate wearing anything at all around my neck), but I think if you were the type that's inclined to do that it would work very well for that. It's slim design wouldn't stand out under the shirt and with how light it is it wouldn't be bothersome hanging from your neck.
The large front choil gives me a surprisingly secure grip. I have much more control with cuts than I expected from a knife so thin and small. I pinch it between my index finger and thumb, with my middle finger not applying pressure, just being there to help steady it. The spine jimping struck me as odd though, because my most commonly used grip has my thumb resting in between the two sections of it. I think it would of been better to just have one long strip of jimping. The forward section is nice though, because it helps you retain the knife when choking up for more point-orientated work, which this knife excels at.
One issue I found with the sheath design is that if you wish to cord wrap the handle or apply scales, you can only go as far as the second hole in the handle. If you try to wrap around the front choil you won't be able to sheath the knife, as I found out. Not much of an issue for me, since I prefer the knife unwrapped, but something you might want to keep in mind if you planned to cordwrap one. Overall though the sheath works well. Snaps the blade in and holds it securely. It hasn't ever accidentally released for me. It keeps a thin profile so as to not add much bulk. My sheath is a little different than the stock one, as you'll see in photos. I like how it is (Was shipped to me from A2D2 like this) because I don't intend to wear it as a neck knife, so it makes the package even flatter.
An aspect I like about the knife in comparison to a folder is the simple, one-piece design. Extremely easy to clean. No moving parts, no scales to trap moisture etc. I've had no issues with rust using it in the kitchen to cut veggies and meats, nor with getting it covered in sweat or water. It's actually become one of my favorite knives to peel carrots with, something I do a lot when I cook.
As with every Buck knife I've owned (Large stockman, 110, 112) I felt the factory edge was much too obtuse. Eventually I'll reprofile it. For now though I've just been touching it up with a strop and ceramic rod. The S30V blade takes a noticeable amount of effort to get sharp compared to knives I'm used to (SAKs, Byrds, Opinels and carbon steel fixed blades) but I did achieve a hair popping edge with it after some persistence. I haven't noticed anything special in the way of edge-holding compared to the knives I mentioned, which is something S30V is usually noted for. Over time this might change, I haven't had the knife for very long. One more thing I'd change about it would be removing the sharpening choil.
Overall I'm happy with the knife, but I'm still not very sure how much I'll use it. I tend to carry large folders, so having something small for precision work is nice, but with a Victorinox Classic on my keychain it seems redundant. Oh well, I like the knife enough that I still carry it. I'd be fine carrying it alone for the majority of my knife tasks. It seems like a knife that could find many uses, such as throwing in a PSK, using on small fish and game, leatherwork etc.
Excellent write up. For the $30 or so, I plan on picking one up. Great design and steel make it look promising.
i have one coming... i had no clue it was so small though, wow
are they all PE? it seems like i saw a CE one
Cheapest piece of S30V this side of Wal-Mart Natives.
Yermom, that was my reaction to the size when I first saw some comparison shots someone here posted of it next to a Buck 110. It's pretty much a one finger knife for me with my middle finger not really gripping it, just closing around it to help stabilize it.
i think when i looked at a less detailed shot, i had the spine and edge side reversed and thought the jimping was serrations
I concur with much of your reivew. I've had mine 2 weeks now. I've worn as a neck knife but found I like it in my pocket. Right now it is riding in my Filson vest. I have not added anything to the sheath. So far it is fine.
The knife is small. I might prefer a half inch bigger, but I really like it. I ran para cord through the holes in the handle with a loop and cinched it tight. The "lanyard" is only a couple inches, but with the knots in in the ends, it serves as an handle extension...
Oh this thing is sharp. Overall a very cool design at adecent price. I'd live to have one sized inbetween this and my Becker Necker.
tjg
That thing is REALLLY tiny..IMHO..almost to the point where it could be made from scrap steel. Also really hard to get a 15 degree edge on it
Nice review Vivi!
What did you do to the sheath? Is that a ranger band on there or did you tape it?
Nice shot in comparison with the SAK, gives a bit of a reference.
Cheers!
I got one a few months back. For some reason, every time I see a pic of one in a magazine, it is without the black coating, and they look a lot nicer than they do with the coating. I may remove the coating on mine, it's not like S30V needs it.
Nice review Vivi!
Cheers!
Thanks. I believe it's just ordinary black electrical tape. The lanyard loop on the bottom of the sheath was ground off too. It came to me this way. I would of taken the loop off myself, but I'm not sure what function the tape serves. It works fine how it is so I haven't removed it.
Tape is for sheath retention (an issue with the Hartsook sheaths last I heard).
Looks good, actually I found S30V to rust a bit more that other stainless steels... maybe it's just me? :confused:
:eek: that thing is tiny ! Im always surprised by size comparisons .
I have to get one of those , i like fb's for edc
I've been edc'ing one since early December when a friend gave me one for doing him some favors. At first I thought I would not ever find a use for it. In fact I looked at it like a joke, but the joke was on me. Once I started to carry it so as not to hurt my friends feelings, I found it to be a handy little knife for all those pesky cutting jobs that don't require a big knife, just a sharp edge. Things like opening my mail, plastic blister packs, plastic food wrappers, UPS boxes, and so on.
Its held an edge very good, and with my small Eze-lap diamond home I carry in my wallet, its easy to touch up when less than razor sharp. In the last 2 and 1/2 months of steady use I've had to use my diamond hone once, but I strop the knife every evening almost, to keep it up.
I've carried it as a neck knife exlusively, on a black cord under my shirt, even with the opening between the two lower most buttons on my shirt. The sheath has shown no problems retaining the knife even on hikes in the woods. If I need it, its easy to reach in the shirt front and pull it out. Even though I carry larger knives like my traditional pocket knives ( a stockman, or an Opinel or sodbuster), I've made it a point to see how much I can do with this little thing. So far it's done everything I usually do with my Vic classic or Case peanut, but with more convience because there is no need to open it.
So far this has been an eye opener. It most certainly opened my eyes and mind to the concept of a small fixed blade knife and the assosiated advantages of that. Simplicity, safty(no folding up if a lock fails).
From first impressions that it was somebodys idea of a joke, and it was some mall ninja fantacy junk for a wannabe James Bond, I've come to love the little Hartsook for what it is- a damm handy little utility knife. If it was a joke, then the joke was on me.:thumbup: :thumbup: :thumbup:
these are turning into a cult knife. iirc, EDCforums had a group buy on them because they got so popular. i've got others that fill that niche, but if you're trying to save pocket real estate, you could do worse.
It's decent knife for its size but mine is far to flimsy to give it any serious work. My upcoming Utility HAK will fill that niche nicely.
Any tasks in particular that you didn't feel comfortable using your Hartsook for?
I second the cult knife phenomenon, I bought one yesterday after all the talk about it. It's definately a nifty little blade, I EDC'd it today, cut pretty well, peeled, etc.
Great discussion, guys. I think I am going to order one. I'm a desk jockey so it sounds like it will do a lot of what I need (mail, boxes, cord, plastic packs, kid's apple needs to be peeled). I also like the size, trying to save on "pocket real estate" myself.
I also like to use my knives on food stuff/kitchen duties and I get a little worried about what micro-scopic bad guys might be hiding in my folders even though I work at keeping them clean. This will work great as an edc fixed blade.
Thanks,
Jim
hi vivi,
i'm glad you're happy with the knife. nice writeup too. any updates on how it's working out for you?
You know, that this is the kind of "no-frills" knife that most would probably give it a miss at first, but then end up buy a dozen of - and still find that it wouldn't hurt none to buy a couple more. Why? Simply because that its unobtrusive, trouble-free and just plain affordable that it would be a major sin not to own (and it's good steel too). Good job Buck!
As for you unbelievers, it's time to go out there and get yourselves some; as I just can't seem to have enough of.
