Hi all. My Buck Haxby has arrived.
WOW....! What a beautiful knife. I absolutely love everything about it.
Here is my honest and straight talking review/opinion.....
When I first unpackaged the Buck, I was instantly hit by it's fine lines and handsome looks. I spent the first couple of minutes just staring at it and inspecting every detail of the knife. I noticed that the blade was a slightly off centre. Not a problem with the workings of the knife, but if centre blades always haunt me. Then I started to flip it open and get the feel of it. My first impression was that it felt light and flimsy. And when I flipped it open I wasn't sure if I liked the sound of it..? The lock up was a good sounding solid click, but it also had a sharp kind of rattling noise that seemed to echo..? On further inspection and messing about, I discovered that the noise I didn't like was from the pivot bearings. I could feel and hear that they were possibly a bit dry..? The action wasn't as smooth as I expected it to be at first. It reminded me of the sound and feeling of metal on metal contact. The Buck flipped open like lightening. Almost a bit too light. So I got my torx driver out and messed about with the pivot screw. It only took me a few minutes to increase the drag ever so slightly. And by doing this, the blade still flew open like lightening, but it had a more sturdy feel and a nice duller sounding lock up. Even by increasing the tension, the blade still free dropped when I pushed the lock over. After solving that issue, I decided to have a go at re centering the blade properly. It was even quicker and easier than I thought. I back the pivot screw right out until it was hanging by a thread, then I used a bit of folded cardboard to slide between the liner and the blade to force it in the opposite direction to where it was leaning to. Then I tightened the pivot screw right down as tight as it would go. Obviously, the blade wouldn't flip open after doing this, but I expected that to be the case cos of other knives I've had to re centre. I took it really slowly and millimetre by millimetre I gently undid the pivot screw and checked the action each time I got a turn on it. Success...
! Perfectly centred blade, a lightning smooth action, and a nice dull solid clunk as it locked up. Time to put a bit of lube in the dry pivot. I didn't dismantle the Buck completely though. No point in going that far. I just a needle oiler to put a couple of miniscule drops of oil each side of the pivot just above the bearings. I rapidly flipped it open and closed it about a dozen times and all of a sudden it really did become a whole different knife. The next thing I noticed was that when I disengaged the liner lock, it made a tiny little squeaking noise as the liner slid across the blade stop. Again,..nothing to worry about. It was just bone dry and the two mating metal surfaces hadn't had time to bed in and form there own shape on the surface of the new steel. So to speed things up, I used an old trick of mine to get rid of the dry squeak and the rough feeling of metal on metal contact...? I used a dentist's pick to apply a tiny tiny bit of my air rifle tuning grease to the detent and the tip of the liner lock. The stuff I use is made for me by a friend who is one of the best UK rifle tuners in the business. He makes the lube by mixing an exact amount of high grade molybdenum grease with an exact amount of graphite powder. You end up with a very thick black grease that has a grey sheen to it. When you use his secret formula grease, an old saying comes to mind...
"Less is more"
And that couldn't be any more true when using this lube.
So what have I got so far.....
I've got a stunningly beautiful Buck Haxby 259 that flies open like a rocket if a butterfly flaps its wings within an inch of the flipper stud. And I've got a Buck Haxby with silk and feather coated bearings that locks up with a fascinating and positive solid thud. And I've got a Buck Haxby that now has a liner lock disengagement that's as smooth as the rest of its team mates.
Mmmmmnnnnnn.......what haven't i checked yet
Oh yes, that's it. The last thing I need to do is check how sharp the blade is.
And I found out the answer within a nano second...
Don't worry, it's not what you're probably thinking I'm gonna say...? All my fingers are intact and I don't need stitches and a blood transfusion.!
My brand new Buck would have struggled to cut through polystyrene even if I'd got my blowtorch out and heated the blade up to a nice cherry red.
But once again,....not a problem whatsoever. Reason being is that I absolutely love sharpening knives. I used a black sharpie to colour in each bevel, and clamped the Buck in my Lansky. I then used the fine honing stone in the 17° ...20°...and 25° settings to establish a near enough angle that my new Buck Haxby "HADN'T been sharpened" to...? I'm not a perfectionist, and nor do I seek it,.....but I quickly discovered that the Buck was somewhere around the 20° mark on each side. (40°) overall edge.
No messing about this time....??
Out comes the Lansky turnbox with the medium and fine ceramic rods that can be set at either 20° or 25°. I went straight to the fine ceramics and stuck the two rods in the 20° holes in the top of the box.
My guesstimate was correct. With only approx a dozen runs on each side of the blade and a few light swipes on a flat leather strop, .....the Buck Haxby changed from Clarke Kent into Superman within literally minutes..!
This thing is now sharper than I've ever got any other knife in my collection before!
CONCLUSION AND FINAL SUMMING UP.........
THE BUCK HAXBY IS WITHOUT A SHADOW OF DOUBT THE MOST BEAUTIFUL AND SOLIDLY BUILT KNIFE I'VE EVER HAD THE PLEASURE OF HANDLING. I HONESTLY WOULDN'T HESITATE TO RECOMMEND THIS SUPERB KNIFE TO ANYONE.
WELL DONE BUCK,....AND WELL DONE CHINA. A FANTASTIC TEAM FOR SURE.
