ah .. i have two centiveveo's to add to this thread
holt hardened hoes then later in life made knives for army air gi's near his home
he tought al to make them from files and large saw blades
it is my understanding that they were sescussfull because
the took their knives to a higher hardness then most every one else did
and they offered sharpening service on them
the general idea back in the 40's and 50's was softer so it was easy to sharpen
esp if you used one a lot and again softer blades did not break so easy also
when buck incorpated they went to stainless steel a 440C
but hardened it much more them others did
bucks oven befor BOS and the 3 dots got hot but
did not have but one heat sensor in the center
this would allow at times for the center batch to be great but
some on the edge might not get as hard through and through
i KNOW from my 1960's and 1970's knives that some knives when warn 1/16 back
they would get to the point they would not take an edge
this improved drasticly in the 3 dots
as
Bos took and put high temp fans in the oven and more heat sensors
thus every blade got the true good temper that most bucks had
Bos was an early expermenter in cold treatment of blades also
so ... i hope i am not wrong on the above
if so
SOME ONE CORRECT ME !!
