Ok guys, here it is the review after using and abusing the Buck Marksman.
Im carrying it since 2 months nearly everyday and it rides in my pocket quite well. (most of the time I dont even notice when its there)
First thing to sort of complain is that the pocket clip is really tight and you need a lot of force to get it out. But thats something you can fix.
When you open it with the flipper it opens really fast because of the ball bearing system. Some people asked me if its an auto folder but its actually not, it opens so fast because of the ball bearing system.
When the sls (strong lock system) engages its almost a fixed blade. In my opinion it isnt very innovative because there were folders with ringlocks, its almost the same lock idea. But thats not a bad thing because when its engaged I was impressed how strong it was. Buck tested it and said that it withstood 600 pounds. I was batoning with it and it hold up great after 3 sticks there was some horizontal blade-play but that was a very easy to fix I only tightened the pivot and it was gone. If the strap wears you can adjust it too. And theres another thing to complain: When you use it a lot the pivot loosens really fast. In the field that really sucks and causes some horizontal blade-play.
Now to the blade its a drop point blade (bee blast finish) and this thing is hair shaving sharp even after 2 months of use I only strapped it a couple of times. I was really impressed and I believe its just because of the bos heat threat.
Closing the blade: You need to get used to but you can close it one handed. I do it exactly like the guy in the video: https://www.youtube.com/watch?v=NLzHVlsQn30
The handles: They are made out of aircraft grade aluminium and are anodized. The anodization wears away quite quickly. But the handles are comfortable at least in my hands.
Now a before and after use: (I put gyazo links cause I dont understand that picture system)
Before:http://gyazo.com/b0454883decd8b8f17c4122088262ae8
http://gyazo.com/ad021b68089e451da696ff17c6285db5
http://gyazo.com/c36032848973d8f0f5f9609c811fe45e
After :http://gyazo.com/a0b25d8470a4dcb1a35aedc3b50e9114
http://gyazo.com/d59600df7257daa4414aa4066364b539
And some photos when I was scouting last week: (if you are interested)
http://gyazo.com/643330557e8364b0d36f3043db2de21a
http://gyazo.com/790dbf3fe02b4330f3692fdf70bb4ca1
Pros::thumbup:
-Easy 1 handed use
-Really lightweight
-Holds an edge really long
-Has no bladeplay
-You get something really good for the money
-Possible horizontal and vertical adjustments to eliminate any blade-play
Cons::thumbdn:
-Anodized coating wears away fast
-Pivot gets loose quickly after batoning
-(Tight pocket clip)
I would recommend you to carry a 3mm allen key for adjusting the pivot and eliminating any blade-play. Thats something I really liked, a folder without blad-eplay.
Huh. That was quite a long review, I know that. Its actually my first.
If you have any questions feel free to ask. Maybe I didnt mention something.
And the specs you can find in the internet. I didnt wrote them here because the post would become way too long.
Thx for your patience and time to read this.
Pros::thumbup:
-Easy 1 handed use
-Really lightweight
-Has no bladeplay
Cons::thumbdn:
