**GONE**
Buck Strider 880SP/PE- ATS-34 blade steel, dual thumb studs, with Bos stamp. Lock up is good, even better depending on how you tight you like the pivot. Blade has been sanded to a rather nice satin finish if I do say so myself. Black pocket clip shows some wear and the pocket clip screws on the reverse side were removed and lost long ago. A solid user with plenty of life left in it. No box. **GONE**
**GONE**Buck Strider 881T/PE-BG-42 blade steel, single thumb stud with Bos stamp. Condition is near identical to the above. After sanding down the old finish, there are a few more grind marks than the 880, but it still came out pretty nice. You can also see what looks to be a temper line or some kind or rounded grind descending down to the edge. Not exactly sure what it is but I like to think it's a temper line, but you can be the judge. This one is literally a sharpened prybar and works great as a screwdriver too! No Box. **GONE**
Matador-
Matador-
