- Jun 13, 2009
STR, are you able to make a low rider clip for the buck strider model 889?
Thanks
Thanks
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Thanks
I am new to this forum... I am wondering if you (STR) can still make the low rider clip for my microtedh socom elite m/a? Any info will be
http://www.bladeforums.com/forums/s...ech-Socom-Elite-3-5-Manual-w-low-rider-by-STR
Yes I kept the pattern to copy it so the next time I should not need the folder. However, this does not mean I can be expected to line it all up so it sits as it should. There may be minor adjustment needed once it arrives and this is the case on most anything I do that I make without the folder here to fit it to. In some cases, say for the Manix 2 or Stretch 2 as an example. If I'm asked to do these I can do the clip and it will fit but since I do not own these models I have to use either my Para Military 2 or my Delica 4 which use the same clip. So just because I line up the clip and adjust the tension to one of these does not always mean the line of the clip or the center of the stem will be spot on the money for the model they are ultimately going to be used on. These things can be adjusted into the clip by the owner of them once they arrive though and in those cases I can walk you through it in email once I know. Otherwise just get me the info I need from my work order form and I can fill the order. Thanks
STR
