- Aug 27, 2004
Well, there may already be a review done on the Tarani. I just can't find it.
Cliff made some statements earlier that almost indicate he is talking about two different knives.
For example: in the review in the link he says,
But here in a post he says:
So in both cases the lock was barely engaging the blade when it gave out but one was after a force of 150 to 200 pounds and the other was not any serious force. In both cases apparently the lock face broke. I'm very curious to see the other review on the 882 with the steel lock that this thread was started about. Either that or Cliff's explanation as to why he thinks 150 to 200 pounds of force isn't anything serious.
During one of the high load torques (150 - 200 lbs) with a slight sideways distortion, the liner slipped just enough so that it was barely engaging the blade and since the tang was then only on about 1/3 of the liner it sheared a piece off with a snap and some sparks.
When the Buck/Strider lock disengaged to the extent it was partially making contact I pressed down on the handle and the shear force readily cracked the lock face, again not a serious amount of force, I use the Vapor much heavier all the time.
