Bucklite Max
What do the Buck people think about the new Bucklite Max 486? Compared to the old 422 it's thinner, has a clip, it's very stiff to open and tight. Feels pretty strong right out of the box, comes sharp as can be. No blade play any direction. Has thumb-studs, but one hand opening is slow and you have to be careful, it's so stiff it can easily give you a nasty cut! Overall I like it and think it carries great in pocket, you can't even see a bit of the knife, yet it's easy to withdraw. No chance of it opening in your pocket either, it's so stiff. Just picked this one up and for a bit over 20 dollars I feel it's well worth it.
Tough one handed operation is a bummer. Maybe a drop of lube would help during break in? If its hard one handed, its a bummer they did away with the thumb nail indent on the blade.
I know you didn't ask for other comparisons, but I think the Bantam series are better all around. I like the blade shape of the Bantams better and there are a bunch of different handle designs (orange/white/natural camouflages, black, etc.). The only problem, I suspect it is the same for the Bucklite Max, is the side to side blade play that comes with use. I have tighten them a few times with a well placed whack, but I wish these all had adjustable pivots. But even with that flaw, they are great knives, especially for the price and being made in usa. I will be getting some Bantams to give for christmas gifts.
All that said, I have had an Orange Bucklite Max in my online shopping cart more than once but haven't pulled the trigger.....yet!
Bruce
Jill,
I find them to be very light and comfortable in hand, but the 2 I had both loosened up considerably in less than a year.
My understanding is that plastic is on the soft side and the pivot and lockbar pins can loosen up under hard use.
I hope they bring back the Ecolite. Either that or find a way to make the Bucklite Max a bit tougher.
So, despite the feeling of being very tight and strong, they won't hold up to any use, or just hard usage? In other words what did you use your two for, that caused them to loosen up? The Bucklite 422 pictured with the new one, has made it over 20 years and it has some looseness and it's easy to defeat the lock with a easy spine tap. But, you can't force the lock to close with hand pressure. I'd think the Max would at least be as tough?
Jill,
I think the Bucklite Max folder make great EDC knives, good hunting knives and good backpacking knives, the latter because they're so dang light. I'm planning on getting the large one now that they've changed the blade shape a bit.
IME, all lockbacks tend towards vertical play as they age and all knives have things they're good at and things they're not so good at. I just adjust my expectations and focus on what the knife is good at and avoid things that it's not.
Hard cutting of wood where you exert a lot of opening force on the blade is hard on lockbacks. I have a larger than average property for my area with a lot of junk Maple and other assorted trees and brush. When working around my property, it's not uncommon to need to cut back branches or saplings. If the branch is thumb sized or less, I just use my pocket knife to cut it back as opposed to walking to the barn to get clippers or a hatchet.
We also make fire a lot either in the backyard pit or when camping. In the east, that means making shavings or feathersticks - so again, hard carving cuts.
Pretty much any lock back I've owned will "rock" a bit under this sort of cutting, pushing the lockbar up. Eventually, on some, this can lead to wear of the pivot and lockbar pivot. On the Bucklite Max folders, they got progressively worse both in a year's time. Big slip joints like a Sodbuster and other designs like lock ring type locks seem to stand up to this kind of cutting better for me.
In the end, I still really like large Bucklite Max and may get another for backpacking, where the primary use is food prep and I really need a lightweight folder.
FWIW, I think the "spine wack" test is a poor test of a lockback's strength or safety. The physics of the test are designed to defeat the lockbar design and don't really match any real life scenario that I can think of. I do think that once a lockback has developed a noticeable amount of lock bar rock (lifts up under hard cutting) they become unsafe as they can close in a "sling shot" type failure when you cut through a branch, which momentarily snaps the blade forward while the lock bar is rasied.
If it were me, I would enjoy the 486 for what it is. It's a great lightweight EDC type knife. If I need to cut wood on a regular basis, I would and do reach for something else.
I won't use a folder to cut bigger limbs anyway. The most I do with one is hack smaller green thorns away from hiking trails. If I am doing anything heavy duty, I get a fixed blade, axe, or chainsaw, in that order.
I agree with spine wack is a joke of a test. Plus lateral forces on a folder.
That new Bucklite Max, sure feels very strong out of the box. It's just stiff and has no blade play at all. I'd be surprised if it loosens up the way I intend to use it. Plus, it's freaking sharp, I mean as sharp as a knife comes new.
Just use it for cutting stuff and it will likely outlast you. Those are good knives (and great bang for the Buck:D).
I like the bantam a little better. I just got my bucklite max back from Buck because the grind was horrible. I sent it to them 15 minutes after I opened it. They replaced it and the edge isn't the best but I can fix that. The bantam feels more substantial and I like that blade shape more. I prefer the bucklite pocket clip though. Both are fantastic for the price and I'm sure I'll end up with a few of each...
Just ordered an orange version. Love that low pocket ride.
I just got a Max medium via a trade. Fantastic knife for the price. A great worker. Love the low-ride clip. And American made to boot! :thumbup:
I think you'll be happy with the 486 Jill! I've had this 482 for more then a couple of years and the first year I used it pretty good. It's just as tight and well made as my Ecolites still!
[/URL][/IMG]
Just got one at the Buck Show. Really nice. Im impressed at this price point.
Pliers to the thumb studs? I really liked the Xmas tin ones that came out a few years back with no studs.
