- Apr 26, 2004
I hate to beat up on Buck yet again, but there's something that's been bugging me lately, namely the poor edges I seem to be getting from them lately. I would use the two 444's that I recently purchased as an example, but they both came from an Ebay seller, and were manufactured in 2004. I understand that everyone has a different preference for sharpness, but when a blade won't even begin to slice paper, or even skin, there's a problem. Those two were easily reprofiled, but the two I got today weren't so easy to fix. The first one was a Buck Vantage Select manufactured in 08/2012. It had excellent fit and finish, perfect lockup, and a decent edge. Until you got to the last inch of the blade. The grind there is off by quite a bit, especially at the tip. Looking from the spine side, if the total angle of the blade tip should be 35 degrees, one side was ground at 25 degrees, while the other was ground at 10 degrees. I was able to fix that somewhat, but it doesn't look good at all.
The second one, which I also got today, was a Buck 503 Prince made in 09/2012. The fit and finish were great, but the edge was ground very thick and as a result was dull, while the tip was blunt and ground unevenly. Again, I was able to fix it somewhat, but only after some judicious reprofiling. This seems to be an issue that keeps cropping up on the Buck knives that I have purchased. A Buck Special I recently purchased new actually had rather nice bevels, but then then it looked like someone had hit the blade on the sharpening stone at a much higher angle, leaving a rather blunt final edge. I've noticed the same thing on a 303 I purchased a few months ago as well. The primary edge bevels weren't too bad, but then there seemed to be a very rough, and very thick microbevel put on at the end.
I'm not trying to pick on Buck. Even with the edge issues, I find myself drawn to the brand more and more. I'm mainly interested in seeing if other Buck fans are noticing the same issues, and if so, is there anything Buck can do to fix the problem.
I included a pic of the Vantage, looking at it from the edge. It's a bit blurry, and slightly off, but I think you can see what I'm talking about with the tip of the blade.
Thanks for looking, and please feel free to share your experiences as well.
