- May 2, 2010
Usually BudK knives are for showing off only. You can try to use it but there is a fair chance it will fall apart or get dull very quickly.
I just bought this item...
can someone give me feedback on how it performs...
especially in terms of chopping and batoning.
No offense intended but I would suggest you do your research BEFORE parting with cold hard cash, if you were intent on a bowie style knife perhaps a trip to Walmart for a Buck 119 would've been a better option :thumbup:
Be very careful with that thing when you test it. There is an excellent chance that the handle will come loose, or it might break completely and launch the blade. A knife that size will generate alot of momentum; and, if the only thing holding it together are a thin rat tail and an alloyed (or even plastic) pommel it will break. Make sure that no one is in the line of fire. Start with light cutting, and progress from there into tougher materials and perhaps eventually chopping. If, you feel the slightest loosening along the way, stop using it iimmediately. It is better to write off $20 as an investment in your knifelore, then to push it and risk many thousands of dollars in damages.
n2s
Any guess if I will be able to return it or sell it back?
I did man. Spent several hours. Just couldn't find the right material except the reseanable reviews on amazon. My problem is I like to try uncommon things.
It's probably safe to say most people here have no experience with it. It's regarded with some condescension, as you can tell. There is nothing wrong with a cheap knife, as long as you're happy with it. However, if it is unsafe, as N2S pointed out, that is a different story. I don't know much about this knife, but if it shows any chance of coming apart during use, I'd send it back, unless you just want to use it to practice sharpening or something.
Many cheap knives are cheap because they are held together with bubble gum and duct tape. If you can prove its not going to come apart, and you only expect $20 worth of performance, you may well be happy with it. That said, for $20 an aftermarket Cold Steel bowie machete may be a much better choice. Buck 119 and similar fixed blades are also good choices, but are more than $20.
Looks kinda uglyA desire to try uncommon things, plus $20 ($14.99 plus S/H) could have gotten you this:
- ·Fire hardened carbon steel blade with orange coating
- ·Flexible temper grooves
- ·Wooden handle with double brass rivets
- ·Full tang construction
- ·10" blade
- ·15" overall
- ·Lanyard hole
- ·Nylon belt sheath with utility pocket and sharpening stone
- ·Made in El Salvador by people who know how to survive in the jungle!
Not a fan of the orange blade :thumbdn:
Looks kinda ugly
Anyways, how does it chop? Done any batoning?
and, have you had experience with other knives in the past?
Do you have link for the site?
