- Oct 19, 2009
I snagged a CS True Flight thrower a while back. I never did feel up to practicing throws for hours at a time, but I did use it as a comparison knife for some heavy duty bushcraft jobs. To my surprise it has done well. It handles batoning quite well, including some abuse in very sappy & knotty shrub wood, and point-first batoning into seasoned apple. It's hefty enough to do some chopping. I beat the heck out of it and it shows no sign of giving up. The edge is holding up 10 times better than I assumed it would. It takes careful technique to cut thin curls (angle the knife like a skew plane) but it is doable. As you'd expect with a thrower, the point is robust. There is a short 2" swedge but it doesn't really get narrow until the last .5" or so... a good thing IMO because a sharper swedge chews up a baton so quickly.
The True Flight is 5mm thick (almost .200") 1055 carbon, midway saber grind (and a fairly obtuse edge), full profile tang, 12" OAL with a 6" edge, and 9.7 oz. The handle is wrapped with what looks like paracord. I put a ranger band (bike tube) over the cord wrap to add a little thickness and a lot of grip. There are two holes in the tang for securing the cord - these holes could be used to secure micarta scales too, for anyone so inclined.
The stock photo above shows a much higher grind than mine has.
I can't think of another $20 knife that'll work half as well in high-impact chores. If you need a beater knife for the boat or camper, you could do a lot worse than this one.
