- Jul 21, 2020
Hi all,
After spending countless hours on google, forums, and youtube, I have decided it might be easier to pose the question to experts with my specific requirements instead of getting lost in the labyrinth of information on the web....and getting nowhere close to my goal
I am looking for a general all-purpose fixed blade knife (or a couple of them) to suit a variety of needs. The primary purpose of the knife is for hiking/camping followed closely by buschcraft/survival. It doesn't need to fit any use case perfectly but it should serve the general need well. I have listed what I feel are my requirements and I would greatly appreciate your feedback on 1) knife recommendations and 2)whether the logic for the requirements are sound and if alternate options make sense.
These are my must-have requirements: (at least I think so
The following are features that are very nice to have but if it comes down to it, I'd give these up before I give up the must-haves.
I am appreciative of any feedback you might have and I hope to get some good recommendations for a key component of my hiking/survival kit.
THANK you all in advance!
OneWithNature
- Full Tang ( I am guessing this makes sense since the knife must be strong with minimal chance of failure)
- Relatively prominent front finger guard ( this is to prevent accidents when I bear forward on the knives.
- Knife Grind order of preference: Scandi > Sabre > Flat . I am picking these grinds since they seem easy to field sharpen and some of the research indicates a hollow grind is generally weaker compared to the others since there is a thinner thickness behind the edge. I am assuming this also means that regularly resharpening the hollow grind ends up making the blade edge weaker as the knife edges come higher up the hollow grind surface. This is one of the requirements I am most torn about since I also see youtube reviews of folks absolutely pounding knives with hollow grinds and they seem to hold up well without curving or bending. Open to suggestions on changing this preference)
- Very good edge retention
- Strong blade.
- Relatively easy to sharpen (and yes, I know this is usually conversely related to #4 and #5 and given a choice, i'd pick better edge retention and strength over ease of sharpening)
- AND BUDGET.... This had to be in the must-have list.
While I'm open to paying a little more for better features, I am looking for knives under $75 USD. The lesser the better. I'm hoping for a good knife filling my requirements under 50 bucks ( I did say hope, didn't I?
) - no secondary bevels.(having a single bevel to sharpen is easier than maintaining to two bevel edges)
- Flat knife edge (since it is tougher to maintain serrated edges)
- Rear finger guard (to prevent my hand from slipping from the knife when i use the pommel to tap/hammer.)
- flat pommel
- Drop point or clip point blade
- blade length between 4-6 inches
- Type of steel (doesn't matter): I think I will keep the knife clean enough so i won't have to worry about rust. But I am not averse to Stainless Steel
- Schrade schf38: Missing flat pommel, steel seems average, and various websites list the grind differently (so I just don't know)
- hx rock outdoors: Unsure about the quality of the brand
OneWithNature
