- Feb 17, 2007
A couple guys have commented on how they like my buffer setup so I thought I would post a couple photos. It has 4 arms with a buffer on each. It pivots like a lazy susan and locks in place. A real wall saver in my small knife shop area. The base is very heavy and was filled with old steel bits and cement with a plywood below that. The 2" pipe column comes up and ends with the thread half of a 2" union salvaged from work. the 4 2x2" angle arms meet in the center and have a stub of 2" pipe and the nut 1/2 of the union. I welded a long bolt on it. When the nut is loose you can turn it to the buffer you want and then use the bolt handle to titen the nut on the union and it will stay put. want another station. Tap the bolt with your hand and it will loosen enough to pivot another into place and then you lock it. I have pivot arm light near the middle and a power strip. so I can position the light at which ever place I want and only one cord coming off the pivot. You can go a couple wraps of the cord in either direction. I just keep an eye on it and unwind or work myself lose on the cord. Jim
