???????? That article is about using a wheel grinder? Few knifemakers use one of those.
However, the general safety instructions are good for any tool, and bear repeating:
General Precautions
•Keep a regular maintenance/inspection cycle and keep a log in your shop tool binder.
•Read the tool's manual carefully-spend a minimum of 1/2 hour on it. And review it once in a while. Follow its instructions carefully when changing parts or accessories.
•Wear adequate eye and hearing protection. Wear hair up and avoid loose clothing or jewelry.
•Do not talk to anyone while using this machine.
•Do not have any distractions while grinding.
•Keep powerful tools in their own small area, free of clutter, preferably with at least low walls around the area to isolate the tool and debris from it.
•Have good housekeeping and clean the area around the tool after every use.
•Make sure local ventilation is appropriate for the tool
•Have good lighting on the working area of the wheel, a mounted desk lamp or one on each side is good (illumination from two sides eliminates shadows)
•Always have the machine properly mounted and screwed securely in place onto a sturdy work surface.
•Turn off the machine when not in use.
•No children in the workshop.
