First off I grind down to a 9 micron finish before going onto the buffer. 1st step the black compound. I reload the wheel often, and it is easy to tell when the wheel needs to be reloaded with compound as the wheel looses that resistance and simply wants to spin and heat up the blade rather than buff.
When I first start up the buffer I dress the wheel using an old hack saw blade- you know the ones that are about 12 inches long and about an inch and a half wide. Turn buffer on, and make a couple of passes over the spinning wheel to get the old compound off. Then apply the compound to the spinning wheel using light pressure and coat completely. Use only enough to coat the wheel or it will just fly off as it spins.
When buffing use light pressure. Heavy pressure risks the chance of causing orange peel on the finish or very quickly an accident. If orange peel happens, then one has to go back to the grinder and start over again from the 320 step.
Once the blade is cleaned up and has that mirror finish and all the scratches are gone, then it is on to the Green Chrome rouge to bring the luster up. Use a different wheel for each compound. Scratches from previous grinding steps often show up, and often one has to go back a couple steps to the grinder- that's just the way it is with knifemaking. Patience and more patience.............
I go one step further and finish up using the fine white aluminum oxide applied to a loose fluffy wheel, for that extra glow. Just be really careful with the loose fluffy wheels as they catch the blade and can easily send it flying across the shop or into your body.
For safety, pay attention to what you are doing, as buffing is the most dangerous step in knifemaking. You must know exactly where the blade is in contact with the raging spinning buffer at all times. Where goggles and a good leather apron too. Gloves are optional. I buff without gloves so that I can have a better feel for the work. Gloves can get sucked into the buffer aswell.
Do not buff if you are angry or in a hurry.
