Bug knives
Feedback: +3 / =0 / -0
The details of the Scarab knife are: Desert Ironwood sits on RWL-34 for both layers of steel. The knife is ‘one sided’ and sits on an attached base of ebony. An ebony spacer seperates the two layers of steel. The dagger is chisel edged (ground on one side to a zero edge) with an 8” mirror hollow grind. The dagger blade is approximately 3 1/2” long and OAL is approximately 8”. Since the edge is 1/2 of the degrees of a normal knife edge, it is very sharp. Screws were used to assemble the bottom layers and hidden pins with epoxy hold the Ironwood in place. This comes in a zippered case. The price for this knife is $475 shipped CONUS.
Hornet BUG KNIFE!
This theme knife is of course a fairly nontraditional piece. An impression of a Hornet should creep in some where or at least some kind of bug anyway. The blade is BG-42 with a convex grind and edge. Box Elder burl stabilized by WSSI forms the body capped off by a 416ss ‘bolster’. Stainless wires are heat colored for the legs and held in small copper tubes in the ‘thorax’ so the wood doesn’t split from the torque of the legs. The legs are not attached and simply push in and pull out. The blade is nearly 4 3/4” and it’s about 9” OAL (and it’s 5” wide!). This will come in a canvas zippered case.
More pictures of both are here
77 views and not ONE comment?
Jeesh~
lighten up Francis!
this is a prime example of "thinking outside the box"...
a fine idea and set into motion by a master craftsman, Tracy Mickley!
I think he's a little off his rocker [nothing to do with these knives or any others] , but these are very fine pieces, none the less!
enjoy the work and order yours while they're hott!
You couldn't ask for a finer gentleman to deal with and his workmanship /warranty is phenominal.
Ron
I've never commented on any specific knife before, but I just want to say these knives/sculptures are absolutely amazing. I saw them earlier when you had posted them up in the Gallery forum, and was blown away. Beautiful, creative, unique work.
Tracy,
Great imagination and artistry!! :thumbup: I collect mostly Customs, and if I wasn't so broke right now, I'd have one of these "Inscects" on display in my office before the Holidays were over. Keep up the great work, and keep those imaginative designs coming. I'll be back in the Black soon enough.
Ken
