LMT66
- Jun 18, 2008
You might consider digging a small [hand width and depth] ditch from outside,under the wall to the fire pit and cover it with flat stones/bark and dirt to make a tunnel/ outside air source for your fire rather than sucking cold air through the door. You can put a flat rock over the outside to control the air flow. Your fire will burn a lot hotter with a dedicated air source and you will be warmer with no cold air flow coming through the door.--KV
This sounds like a good idea and I think it might work well. Hot fire=less smoke. Thanks for the tip.
