I want to clarify - I am not scared by the science or getting wrapped up - I am simply trying to understand the things I quite often can not see with the naked eye. I do practice a lot - but when I have a poor fire going - I wonder what is happening and quite often can't answer my questions.
There are many variables that can result in an insufficient fire, my friend. But, it generally will boil down to one of these three: fuel, oxygen, ignition. You have an imbalance in them somewhere, one is too high and the others too low; or one is too low and the others too high. Finding out what is causing your fire to be shabby can be an involved process: is your fuel damp? Punky? A little green? Some woods won't burn for shit when you need heat, some burn too fast. Do you have too much fuel on the fire and your kindling hasn't had time to reach peak burn? Are you letting enough air get to your coals and flame? Are you trying to start it directly on top of the ground? (remember a fire needs air underneath it, too).
Knowing more about what is scientifically taking place helps me answer these questions.
You mean at the atomic level, or just the process by which fire is achieved? There really isn't a set amount of space to place logs to get an optimal efficiency. Some wood might have more air space in it as a result of how it grew, some might be more dense. All of this is adjusted as your fire grows.
Concerning science - I simply look at human life conditions and expectancy before the 1,500's and after. The revival of the scientific methods have allowed humans to make more progress in 500 years than perhaps the first hundred thousand years. However, you don't need to go back that far - look at the period from about 400 AD to 1,200 AD in the Western World - incredibly little progress. Compare than from 1,400 to today. From the plague to super computers.
If you look at the advances in metalurgy in the last 100 years in comparison to the dawn of homosapiens - the difference is night and day. I think trial and error can get you some of this - but scientific testing and discovery is owed the lions share.
Actually, I think human curiosity is owed the lion's share. Science is a byproduct of that. Science is only a name for a refined process of discovery and examination. Science is not all that allowed humans to perform these feats.
The difference is night and day, because of continual discovery and refinement. Wood to fire hardened wood, to stone, to copper, to bronze, to iron, to steel, and so on.
Without the human element to ask the question that begs the answer science cannot exist.
Science simply replaced theistic belief in the realm of explaining the processes that occur both: on Earth and in space.
If the other side had won we'd be talking about the merits of a deity giving us these materials, etc...
It's all a matter of perspective.
(Note: I did not, will not, and was not even trying to bring religion into this talk).
But, that is off topic and probably should be handled in another forum.
TF
That's cool. I don't think anyone was accusing or asserting that you were doing such a thing, that I could tell anyway. When I said "philosophy" I was meaning that Lundin has a certain philosophy about things and sometimes, when a person has that kind of perspective on a subject, they tend to talk in such a way that only they fully understand. This makes it hard for anyone listening to sift through, whereas if he'd just say: lay your wood too close together and you smother your fire, too far apart and it won't catch -- so it will die out on you.
There's really no scientific formula to it, well not insasmuch as set parameters of the type "x amount of inches from coal bed for all Birch to burn at max potential, x amount of inches from coal bed for Beech, etc..." Wood is a living material, and as such is given to all the irregularities that accompany that.
The only set pattern is that of: tinder, kindling, fuel; and oxygen, fuel, ignition source. Wait until one is burning at its hottest before adding the other or you'll smother it. Way too long and it'll die. Learning to judge this comes with practice.
When you get it started, if your fire is burning slow or cold push the coals closer together and add a little more kindling. Let it get hot and then add a little fuel.
Like I said: It's like throwing a baseball and shooting traditional archery. You learn to judge the distance and accuracy with practice.
With fire, you learn to judge when to add fuel, how far apart to put the logs, etc...a little better each time.
