- Oct 4, 2017
Most homebuilt power hammers I see are the "tire hammer" type. If I am going to build a power hammer, is this the design to use? Just go with the tried and true?
A design that I am curious if it would work is based off of an auto airsoft gun. I am not sure If it would work with heavier parts.
I play airsoft and recently my automatic ak 47's gearbox stuck and I had to pull it out and fix it. The way they work is there is a cylinder that holds a piston. This piston has a spring in it and also teeth along one side. A gear that is about half teeth catches the teeth on the piston, pulls it back and then when the teeth on the gear run out, the piston slips off and the spring pushes it forward and shoots the bb.
Do you think this would work with lifting a ~50 lb block and letting it drop?
Here's a drawing:
Thoughts?
Here's a drawing:
Thoughts?
