Last time I used kitchen oven I make mess , huge mess
I put in oven to temper three relative long Parang from 15N20 steel . I set temp. on 250 celsius ........BUT I forgot to clean blade from quenching in oil .You can imagine what happened....smoke and smell as on the battlefield
If I repeat that I will slip in my shop for rest of my life
So I decide to make tempering oven .I will use 4 heater from two toast oven /they are cheap and easy to find for replacement / and all necessary electrical equipment ,the same one is used in HT oven .Dimension of chamber ..... 450cm. long , 12cm. height and 15 cm width . I like to hear from you guys what do you think of this building concept ? I want to build this thing as best as I can .I have available whatever material you think is best to use ? My plan is this .......................
1. 1 - 1,5mm stainlees sheet
2. 5 cm. kaowool
3.ceramic tile ??????????????????????
4. heater ...they a rated to 750celsius , so I think that I can temper even on 400-450 celsius ??
5. glass ceramics as radiation shield ?????????????
6. internal fan for air circulation
2. 5 cm. kaowool
