Building tempering Oven
Yes, the muffle is what protects the blades from direct exposure to the hot elements. The metal would replace what you had as glass.
Well , don t get angry on me :) I have not started building yet . . . I was thinking about marquenching and on melted lead ...melted tin , and I get some idea ... again:D What if I make tempering oven like on this drawing ?? Square shape and one heater on every side of oven , thermocouple in the middle and filled with AO sand which I already have a lot ?
It is more simple to build and have some great advantage......I think ? I don t care how much time it will take to get to set temp. Heaters I have can go as far as 750 C degrees . . .so marquenching is possible , too ? What do you think guys about this ? I can install even air to mix sand , just like in sand pot I work on ?
IIRC, lead-tin alloys are not good for this, as the tin forms intermetallic compounds with the steel, leading to embrittlement. Lead-Bismuth Eutectic is effective, but Bismuth is pretty spendy stuff. Hence the widespread use of salts, which are much cheaper.
I think Verhoeven covers it in detail.
AO sand is probably not a good enough conductor to give the initial quench unless fluidised. It might be viable to fluidise for the first minute or two, then stop the air.
Thanks for the reply ,@timgunn1962 :thumbsup: Yes , no lead no tin but AO sand is good choice ? And safe . I read a lot pass week about mar-quench.... Plan is to quench blade in oil to black color and immediately in tempering oven already preheated to set temperature . . . I don t see why this would not work ? Air will serve for even temp inside and easy to put blade in sand .I still have to much work on my daily job ,summer still don t want to go away :) And I work on too much project in same time ,this is my biggest flaw :(
Finally I start with this project ....I decide on this dimension 35 x 25 x 25 cm .I need to drill some more hole ...for TC , for metal shields for heat elements , for fan and to cut tile on dimension , then glue everything with high temp. silicone and make angle iron frame and to make door , for which I have excellent idea .I will use 5 cm . stone wool for insulation .
This picture is up side down ...
I can t enter in my shop anymore .....to much project unfinished:mad: I promise to myself to use this quarantine time to finish every one ! I will start with this tempering oven .This is stone/mineral or whatever name wool insulation , rated to 800 Celsius .It is not pressed/that one will smoke some period/ thickness is two inch .So what do you think ? One layer or two ? Or maybe second one from pressed wool ???? I have it enough , it is so cheap that I do not have the spare ? Plan is to use this oven up to somewhere 550 Celsius ...HT element are rated to 750 Celsius ...
Also i have no problem with larger outlying dimensions, when I clean the shop there will be room for dancing :D
PS . That light aluminum frame is just example for dimension .Real one will be from stainless and big enough to cover edges of insulation......
The only machine capable to bend sheet steel in a way i want is not in proper condition and will not work for the next two months...No way I would weld frame from angle iron , so if you read in a newspaper that one town in Macedonia was burned to the ground ............. you know the culprit :D
I can t wait , I need to see if this will work so .........
Who knows ....maybe at the end this is not bad idea ?
I plan two door , one from ceramic tile will slide on side and over that real door with insulation .....
This days i will weld inner chamber/mufle/ from stainless and work on fan..........
I have other plans for fan but today I found original new one for electric stove.... So here it is , I make some stand from 2.5mm stainless ,there is enough place for one layer of insulation between fans.. ...One step closer:)
Well , i m ready to put HT element ,TC , fan and wire them .Fan is also ready , maybe shim here and there to align it perfect with hole in back side but it is 99% done ..And of course to align that wool in right way .On inner chamber and door i can work later .I have question before I do that .This is thin mirror polished aluminium plate /from old Solarium/ .I know that will not make harm if I use it between wood and wool , but did will make any good with heat reflection ? What do you think ,worth effort ?
I was playing with this thing almost all day last Sunday. HT elements are connected parallel and it take 15 min. to reach 200 Celsius with fan ON from start , with door side not insulated yet. Without fan it is way more slower............. I mount two thermocouple ,one ordinary and contact one inside chamber between two piece of steel . I try lot of things with both TC and fan on/off and all I have to say is ..................FAN ...FAN ...and FAN is mandatory in any tempering oven .
I think that ceramic tile are right decision for this build .With help of thick isolation it take about one minute to drop temperature 1 Celsius ,fan running all time . Next is to connect that MF ..........PID . I found one smart young men which probably know more for PID then Chinese who build it ... :D I read in several place that when SSR fall , most time they fall in close position which is no good in tempering oven so I will use thermal cutoff switch on 250 Celsius for protection .
I have not used muffle inside because I still don't have it open from back side so fan can suck air , but even without muffle air circulated perfectly .....probe with one layer toilet paper .
Now ................ I got three tubes of different diameters , biggest one / 38cm Dia./ is aluminum rest two are stainless ....IF i don t build from them tempering oven /Up to 550 Celsius/ in two hour I will quit this hobby !! I do not know what I was thinking ! How I hadn't thought of that before :mad: And i already have build two HT oven like that ????
It can t be simple then this .............................
Ok , some update ...
I make some change to this thing...............I needed PID /only one i have/ for other HT oven so I buy kitchen oven thermostat ...spare part for oven in my kitchen, Made in Germany.
For test I insert tube from thermostat in place of Thermocouple .I used my other temperature control for reference , tip of probe clamped between two pieces of steel and also I used this infrared /expensive one/ for control temperature...........
Well this thing work surprisingly accurate , of course with fan always ON ..........accurate data when i finish rack and make more tests .
Now i want to make new rack for knives ..................What do you think ? I think that IF probe from thermostat is there/look drawing/ oven would be even more accurate ?It will measure temperature of that steel ...That mean that temperature of tempering steel would be same .
I will get another device for measuring the temperature and I will set it up in the same way as the oven thermostat. It will be used to control and fine-tune the thermostat knob to the right temperature.
Picture from internet of one thermostat , just to get idea how it look , it is not same like mine ........
I already start to work on new rack for knives , in this way it will not interfere with the air flow in oven
The other day I used this tempering oven a lot / 52100 bainite / and I have time to observe how it works .........
It take about 20 min. to reach 230 Celsius . After that the cycles are like this....
230 Celsius ................................................5 min. stay on that temperature and in next 3min. temperature drop to 226 Celsius .
ON for about one minute and temperature raise to 230 celsius .......... Fan always ON . More then enough precise for me .
temperature sensor is inserted in that 6 mm thick steel .Almost exactly the same behavior has on 190 Celisius
Without fan always ON ...... simple answer is I don t LIKE IT !! Complicated behavior ! HT element get red hot till oven reach set temperature, changes in temperature are greater ,cycling is erratic ..................
If temperature sensor is in air , cycles ON/OFF are shorter but / Interesting / STEEL stay on same temperature all time , not even 1 Celsius change ..... but I choose 226/230 C for energy saving . +/- 2 C degree is enough for me .Sayonara PID controller 🤣
I think that mete mete / R.I.P./ was right , ceramic tile were the right choice for this build ...........
