- Feb 17, 2007
I was out in my shop finishing a couple blades and using my disk grinder and my bench grinder/ buffers and have come up with a plan to built a new piece of equipment. I have ordered a VFD good for 1 hp that uses 110v input and has 220 3 phase output. A 1hp 3 ph TECF motor. Plus 4 sets of 3/4" pillow block bearings and 2 9" cast iron disks. I plan to mount the motor on a plate and have a receiver socket similar to a KMG (except welded together) mounted on the motor plate. The square tube that slides into the receiver will have a piece of 2" angle welded on one end to form a T and I will mount the pillow blocks on the angle with the addition of some tabs. I have some 1" round stock I will turn each end down to 3/4". One end I will set up to take a V belt pulley about 6" in. Then I will thread the remainder of both ends so I can mount buffer wheels. One of the shafts will have the ends turned to accepted the keyed 9" disks, though I may put a 12" on one end. I think I will make the buffer wheels be about 18" apart I will mount the VFD and have a 10k pot mounted near the machine to control the speed and a switch to control direction of rotation. I am going to have a foot switch to start and stop the motor. To change buffers or have a disk grinder you simply loosen a knob on the receiver and slack the drive belt and remove it from the motor's pulley and then remove the set of buffers being used, reinstall the belt on the next set or the disk set, slide that set in the receiver, put the belt on the motor pulley and pull out to tighten the belt and tighten the knob on the receiver. Yes, I will take pictures as I go.
Does this sound like a good plan. Any thoughts or additions and would any one want one of these if it works out and I can make them for under $1000 with a disk set up and 2 buffer shaft set ups?
