Off Topic Bulk Firesteels?
Feedback: +0 / =0 / -0
I am interested in starting a business selling Flint and steel kits. I have a large quantity of flint, plus can include some quartz or agate, char cloth and tins are not a problem, and I may consider selling some kits with a jute bag or a leather pouch. However, the steel strikers are a problem.
Long story short, does anyone know where it is possible to buy bulk Firesteels, or need I find someone who can make them
Please note; Firesteels, not ferro rods
As above
Ferro: indicating a property of iron or the presence of iron.
Unless of course the OP is referring to the 'horseshoe-shaped' (and/or many other shapes)striking steels steels?
For example here from the Emberlit page:
From the Iron Age to the invention of the sissy friction match, flint and steel is how fire was made. The Romans enjoyed evening gladiatorial battles to the angry light of bonfires spat forth by flint and steel. For a Viking nothing was more relaxing after a long day of pillaging than a drunken evening of bare knuckles boxing and boastful stories of conquest around a burning thatched roof cottage set aflame with Flint and Steel. The Pioneer powered through their trek west pulling hand carts across frozen plains and over jagged mountains all the while beset by swarms of locusts the size of lobsters with a smile on their face. Why? Because they where fueled by whole Bison, spit roasted over fires they started with flint and steel.
The Emberlit Strike-A-Light is a new take on an old idea. While our forebears made do with plain bits of steel these custom strikers are designed to be worn as pendants, zipper pulls, or other decorations, and sized to be conveniently stashed in a kit or fit in an altoids tin. Each design has been carefully chosen to be functional as well as visually unique. Emberlit strikers are made from superb high carbon steel professionally heat treated to the optimal hardness for throwing showers of hot sparks. Get a custom Emberlit flint striker so you can light fires with style and without shame. Save those matches for freshening the bathroom.
These striking steels come in all sorts of shapes and sizes.
Here the ESEE striking steel
https://www.knifecenter.com/item/RCFIRESTEEL/esee-knives-fire-steel-1095-carbon-steel
The ESEE Knives Fire Steel is built from 1095 Carbon Steel and heat treated to be used as a fire making tool for use with true flint and charred material. The edges of the Fire Steel also work as a Ferrocerium (Ferro) rod striker, and the center divot is designed to be used as a bow drill socket. The Fire Steel comes packaged in a hinged-lid tin that can be used to make char cloth or other charred materials. Fire Steel size: 1.5" x 3.25" x .188" thick.
USING THE FIRE STEEL FOR TRUE FLINT AND STEEL:
Break a piece of natural flint or chert rock until you have a sharp edge. Hold a piece of char cloth on top of the flint’s sharp edge using your thumb and index finger. With the other hand, hold the Fire Steel with your thumb in the divot hole so one of the long Fire Steel edges is facing outward. Strike the flat face of the long edge in a downward motion along the sharp edge of the flint. This should be a smooth glancing stroke that lightly touches the edge of your flint as you strike. If you abruptly slam the steel into the flint it will break and dull the edge of your flint. Done properly, the sharp edge of the flint will shave a microscopic piece of the hardened steel away from the Fire Steel. During this process, this small piece of steel turns into a molten spark that will fly upwards as your Fire Steel travels downward. Keep striking until one of those sparks lands on the charred material and begins to glow (this is known as “catching a spark”). After you catch the spark, lightly blow on it until it expands in size, then place it in the center of your tinder bundle. Gently wrap the tinder bundle around this coal and blow on it until it bursts into flame.
USING THE METAL CONTAINER (TIN):
The tin can be used to make char cloth, or to char other natural materials. Properly charred material will readily catch a spark from true flint and steel, as well as a Ferro rod. Charred materials can be carried in your kit to provide an easy way to start fires using both primitive and modern methods. It should be noted that if you plan on using charred material to catch a spark from true flint and steel, the char should be stored and/or carried in a waterproof container so it doesn’t absorb humidity and moisture.
HOW TO MAKE CHAR CLOTH:
Use any 100% cotton materials (no synthetics) and cut it into squares roughly the size of the tin. Place the cut pieces in the tin and put the tin on a heat source such as hot coals. As the tin heats up you will begin to see smoke coming from around the lid (The material inside is smoldering because it lacks the oxygen needed to catch flame). Once the smoke stops, the material should be completely charred black and easily torn. Remove it from the heat source and allow it to cool before opening. It is now ready to use. There are numerous natural materials that can be charred in the same way: Punk wood (soft hardwood going into the rotting stage) and the inner bark of some trees such as Poplar are a couple of examples.
USING THE FIRE STEEL AS A FERROCERIUM ROD STRIKER:
Hold the Ferro rod in one hand and rake the edge of the steel down the Ferro rod. It will cause a shower of sparks from the Ferro rod. There are several different methods of using the Ferro rod, so find what works best for you. One way is to firmly plant your hand holding the Fire Steel on the ground over your tinder bundle, then quickly pull the Ferro rod upwards (away from the tinder bundle) raking it along the steel’s edge. When done correctly the sparks will fall into the tinder.
USING THE FIRE STEEL AS A BOW DRILL SOCKET:
Hold the Fire Steel with the divot side down. Insert the top of the bow drill spindle into the divot. While bow drilling the Fire Steel tends to heat up, so you may have to “cup” the steel using the tips of your fingers and the bottom of your palm. You can also add insulation between your palm and the Fire Steel using green leaves, a small green stick, a piece of your shirt, a glove, or other materials.
He is talking about a metal striker for hitting natural flint, not a ferrocium rod.
Any decent blacksmith should be able to make a bunch for you.
Or have them laser or water jet cut and batch heat treated. Would be pretty easy to get ones of your own design done up.
This guy knows what's up! I bet he doesn't recall him helping me but he's very informed! If I were you (op) I'd call a large manufacture that you can easily find and ask.
Hope we're good (this is the internet after all) I'm guessing the like is good? You know the market and helped me with a Condor question! You are very knowledgeable sir!
Any recommendations on manufacturers? Please note that I have only $500 and some of it has to go to buying tins. I do know two blacksmiths, one made my knife for $110 (metal parts only) and the other is inexperienced but may work for less.
