Are you sitting down?
1.Open your knife
2. Tighten your pivots tight
3. Tape the blade so you don't cut yourself
4. Grab that puppy and put it across your knee at the pivot point with the side thats rubbing away from you and pull.
5. This will fubar most folders but seens to do the trick.
or call (208)265-8858
Bob Taylor
Some days it's not worth chewing through the restraints and escaping.
1.Open your knife
Bob Taylor
I thought I was the only one brave enough to use the ole stretching technique. It works, and with a knife like the rekat you don't have to worry about messing with liner-lock tolerances.
