- Apr 17, 2009
NICE !!!
Well, there ya go. Thanks guys.
I don't take the blades up to a high grit on the belt any more... but the Hermes (blue abrasive, yellow backing) J flex belts are my favorite handle and guard contour belts!
They're $2.40 each from Pop's, or $2.50 each/10 from TruGrit.![]()
Michael, You prefer the Klingspor over the Hermes J super flex? I know that the Hermes Ceramic belts are terrible but there A/O belts are the ones I prefer over all others I have used.
Actually, Hermes has some new ceramic belts (green) that are great, and much cheaper than Blaze or the Cubitron belts.
Also yes, the Blue J-flex belts have an excellent splice that is *much* smoother than the yellow belts.
Personally however, I'm using the Hermes ceramic J-flex belts and the Y-weight Blaze 120's now. They each outlast about half a dozen of the yellow or blue AO j-flexes. Give them a try, Pop has both.
Javand
I had the local Hermes Rep give me 30 of those green ceramic's 10 each of 36, 60 & 120 grit as a test for Scott at Tru-grit. The 36 grit where cut crooked and I didn't even get one of my 7 3/4" Asian chefs knives bevel ground from one belt. Of all of the different ceramic belts I have used they are at the bottom.
The VSM belts that I get from Scott I easily get the primary bevel do on the same knife on one, to one and a half. Try the VSM or the Merit best Value "Norton" belts from Scott. I am sure you will find them better than those Ceramic green Hermes for hogging off metal up to 120 grit..
I buy the VSM belts, they're also very good.
All of the first green ceramics I bought were great, but I have heard of a bunch of wobbly belts lately from friends.. Not sure wtf is with that.
I don't personally use many 36 grit belts, almost none, and typically just buy those in the 984F Cubitron II's, since they are undoubtedly the best I've ever used. I do buy the VSM or the Green 60's and 80's, and none of the ones I've had so far were bad, but I bought a ton of them a while back. I also recently bought a bunch of the 120 green belts though, and they've all been champs. So dunno what's up with Hermes QC. I like how the green ones cut better than the VSM's personally though, FWIW.
I haven't tried the 120 VSM's though, are they J weight?
I wanted to add... I tried the new cubitron 2 belts that tru grit has, and they are really something special. They may replace the VSM belts in some cases for me.
