ccblademan1975
Master of Sharp Objects
- Jan 4, 2011
Trying to thin down collection as I am out of storage space so would like to trade more than one knife for some higher end stuff if possible, if your interested in any of these items please email me at ccwow5527@gmail.com and if you would like I can give you my cell number to discuss trades in finer detail.
I will state conditions of all knives and have pics of most available and can be made available if they are not! Thank you. =)
1. A.G. Russell frame lock spear point. Weighs less than 3 oz. 154 cm steel. light scratch on blade. 3inch blade length titanium handle RC 59-61, 3 3/4 inch closed length. Includes box. approx 90% new condition.
2. Al Mar Falcon Ultralight (N.I.B. condition) has been dress carried once. Aus 8 blade at 57-59 RC. Made in Japan. 3 1/8" sabre ground blade, 4" closed. Removable/Reversable pocket clip, weighs a mere 1.2 oz.
3. Al Mar knives Payara (N.I.B.) Satin VG10 blade 4" length, textured G10 handle scales, double thumbstuds and black stainless steel pocket clip. Overall length 8.5" bade thickness 0.12" weight 6 oz. Action: Liner Lock.
4. Benchmade red box Tanto Vex. *(discontinued)* is a user, but in 85% to 90% condition. Has had a lanyard attached which can be easily removed and had been sharpened. razor sharp. blade material BP coated 8cr14moV SS hardened to 57-58 RC. blade length (4.29" 98.37 cm) blade thicknes (0.108" 2.74mm) length closed (4.43" 11.25cm) weight 4.9 oz. Black G10 handle scales, BP coated stainless steel liners, removable reversable steel carry clip.
Handle thickness (0.541" 13.74mm) Modifies locking liner made in China. But like spyderco, benchmade's chinese products rival alot of made in u.s.a. with lesser materials stuff.
5. Benchmade 556SBK0D Mini Griptillian OD green handle, black half serrated blade. Approximately 13 years old. (was my first benchmade) has been sharpened once but no blade scratches so other than the sharpening on my CRKT ceramic slide sharp it is as new. Has box and bag as well.
6. Boker magnum KAL-74B Kalishnikov. Grey handle black blade combo edge. (N.I.B) box shaped like an AK magazine.
7. (N.I.B) Boker plus "bokermatic" grey handle, satin blade.
8. Boker magnum, patrol liner lock. All metal construction with wooden scales (didn't designate type of wood) on a blue handle. Satin blade. Been sharpened and carried once but I don't believe you could find a scratch on it.
9. Boker Plus 3 1/4" cermaic blade (black) grey titanium framelock handle. handle has small scratches on back side which will not photograph but they are barely noticable till pointed out, blade is in perfect condition.
extremely light.
10. Ontario Knife Company Bush Series Afghan 10 inch overall 1095 5 inch blade with coating. Nylon sheath molle compatible with Kydex insert. Called black micarta hand scales but really more of a green tinge. I wouls say (N.I.B) but it came in a bag which i no longer have. But the knife is new and unused.
11. Smith and Wesson extreme ops folder (been carried no box) (more of a throw in item)
12. Sog Sogzilla, black Zytel handle black 3.8" 8Cr13MoV RC 57-58 with pocket clip. (N.I.B.)
13. Spyderco Superhawk length overall (7 7/8" 200mm) length closed (4 11/16" 119m) hole diameter (9/16 14mm) blade length (3 1/2" 89mm) blade steel VG-10, cutting edge (2 3/4" 71mm) weight (4.4 oz. 125g) blade thickness (5/32" 4mm) handle material - carbon fiber. (N.I.B)
14. (N.I.B.) United Cutlery "the navajo" lockback 472(i think will confirm if interested) 472/2500 David Yellowhorse made each side of the handle from stunning sliver and a band of green turquoise the length of the knife. measures 3 inch closed and has a 2 3/8" hollow ground clip point blade. This is also the first David Yellowhorse knife which he puts his signature as well as the tradition DY mark on the blade of the knife, truly a beautiful peice contains all paperwork a case and even the slip over for the case.
15. (N.I.B.) Spyderco Tenacious. overall length (7 3/4" 197mm) length
closed (4 7/16" 113mm) hole diameter (1/2" 13mm) blade length (3 3/8 86mm) cutting edge 3 3/8 86mm) blade thickness (1/8" 3mm) blade steel 8CR13MOV weight (4 oz. 115g) handle material - black G10 with a walker liner lock and high end components dont let the budget made in china fool you, this knife is one hell of a performer.
16. Winchester par five. Been carried a few times at least 90% good condition have box.
17. (N.I.B.) box slightly rough. Zero Tolerance (Ken Onion Designed) tactical flipper folder. 154cm stainless with tungsten DLC coating. Handle 3d machined G10 in matte black. blade cutting surface (3 7/8" 9.8cm) closed (5 1/7" 13.3cm)
18. Citadel Archer (handmade fixed blade from cambodia) (N.I.B.) technically its a nice pouch with a pocket with a card of authenticity who made it date made and stating its made from DHN7 steel. The knife has not been used and had been oiled and taken care of for storage and has a highly polished blade. Some filework on top of blade, black buffalo horn handle material. the blade is highly polished and the side with the citadel logo is perfect. the other side has black flecks (must have happened during the forging process which I cant seem to remove and are only cosmetic.) it is a beautifly made blade and very sharp. 7 3/4 " overall 2 7/8 DNH7 high carbon blade steel. polished nickel silver boldters and pins, full tang, handmade leather belt sheath and the aforementioned nylon zipper storage pack.
19. Cold Steel Rajah III (used) blade length 3 1/2" blade thickness 4mm overall length 8 3/8 steel: japanese Aus 8 stainless w/bead blast finish. weight 4.4 oz. handle: 4 7/8 long grivory.
20. CRKT Allen Elishewitz Elock starlight. (User) combined razor sharp & triple point serrated cutting edge Aus 8 steel 3.25" blade weighs only 3 oz. Th E lock mechanism (patent pending) which is like a roller switch hard to explain till you use it. CNC machined aluminum handle with strinking pattern machined into it. Closed length 4.12" approx 80% condition needs so reshaping and sharpening done to blade othe than that it can still be used and carried as is, those would just be to make it cosmetically perfect.
21.CRKT ICHI (N.I.B.) blade length (2.5" 6.4cm) thickness (0.096" 0.245cm) steel 420j2 54-56Rc closed length (3.25" 8.3cm) open length (5.625" 14.3cm) weight 1.9 oz (54g) Satin blade, Grey Kraton and Zytel Handles. OptiFast assisted opening system which can be converted to manual open with the removal of one screw.
22. CRKT Klecker N.I.R.K. black on black 3 peice folding knife. Open length 7.63 inches. closed length 4.5 inches. weight 3.5 ounces. Blade length 3.125". thickness 0.131 inches. blade material 2CR13. Rc 51-53. finish- black oxide. hollow ground. untilitarian drop point. Plain edge w/partial serration. handle material 3CR13. Lock mechanism - lock back. 1 position pocket clip.
23. CRKT Lake Sentinal (N.I.B.) other than 1 sharpening. (i prefer my knives razor like) open length 7.75 inches. closed length 4.2 inches. weight 4.7 ounces. blade length 3.5 inches. thickness 0.13 inches. blade material 8Cr14MoV. Rc 58-59 Satin finish on blade, high hollow grind, modified droop point, plain edge. very sharp. handle material 6061 Aluminum & Thuya root, 2CR13 liners, locking liner, Auto LAWKS system. leather sheath, and stag scales on handle. very pretty knife.
24.CRKT Thunderbolt (N.I.B.) overall length open 7.75 inches. closed length 4.31 inches. Weight 5.7 ounces. Blade length 3.437 inches. Thickness 0.13 inches. Material 8Cr14MoV. Rc 58-59. Finish - black oxide coating (looks grey) hollow grind tanto tip with serrations on blade and tanto part of tip. Handle- Anodized aluminum, 2CR13 liners. locking liner with Auto LAWKS system. 1 position pocket clip.
25. (N.I.B.) Fury tactical 9 inch military boot dagger rubberized handle double sided blade, leather sheath.
26. (N.I.B.) Heckler and Koch 14700SBX blade material 440c stainless steel with black coating, drop point with partially serrated edge. Rc 58-60. Weight 4.14 oz. overall length 8.42" closed length 4.68" pocket clip, black movable tip up. lock mechanism Auto open w/safety. (button to open and close) safety is a slide with jimping for grip. comes with box bag and paperwork.
27. Jaguar combo edge folder. Aluminum handle unknown stainless blade material was bought for me as a gift in the virgin islands by my mother, approx 3 inch blade, perfect condition. (N.I.B.)
28. Ka-Bar Besh Wedge B.O.G.A. (N.I.B.) except that it doesnt come with a box its a plastic peice containing the parts against a flat peice of cardboard with the instructions on back so I have all peices in a postal box that it was sent in with the back section of the box included so you have all parts and instructions. But it has not been used.
29. Kershaw Ken Onion Cyclone (N.I.B.) Speedsafe opening, Sandvik 13C26 blade steel. 6061-T6 black anodized aluminum handle. blade length (3 3/4" 9.5 cm) closed length (5" 12.6 cm) weight 6.3 oz. excellent knife smooth as butter action razor sharp blade.
30. (N.I.B.) box is in rough shape though, Blackie Collins designed combo edge blade folder.
31. Mission Knives MPT 12. This knife is what they give the point man on a seal team and it is indestructable as well as expensive. The blade is pure titanium and is as sharp as ny diamond stones would get it. a proffesional sharpening job would probably do better. the blade has a few scratches on it from the sharpening. But the knife is 100% titanium and the handle is Kevlar. Its amazingly light and comes with a kydex molle compatable sheath. amazing knife.
32. OKC/Rat (pre split) Rat 1 folder. Black w black partially serrated blade Aus 8 blade very sharp. liner lock, black G10 handle scales slim profile. Great folder. with randall's adventure training logo on one side of blade.
33. Meyerco Darrel Ralph dezsigned MAXX-Q tactical assisted opener. 95% new condition been carried a few times. 4 1/2 inch closed S30v blade. Assisted opening opens at the touch of the flipper button.
34. HTM Darrell Ralph Gun Hammer exclusive 1 of 20 to true north knives. Assisted open smooth as can be S30v modified drop point blade. Green aluminum military grade handles (the color is what the exclusive is) .9 inch titanium linerlock. Serious tactical folder.
36. new Bob Dozier Master skinner with black rucarta handles, exclusive to AG Russell. But the blade grind is obviously quite differen thsn thise if his standard skinner designs. Knife is immaculate. D2 tool steel Rc60 a'la all Dozier knives. Comes with extra conceal Kydex sheath fitted just for this knife, I did attack a lanyand which you can remove in seconds if you do not care for it. Why wait 6 months to a year if they dont have one in stock when you could have one in days?
37. (N.I.B.) Zero Tolerance 0350 speedsafe folder. S30V blades, beefy linerlock this is the slim version for easier every day carry black G10 withDis black non serrated blade.
38. (N.I.B.) Spyderco Centofante 3 C66BK. Overall length (7 9/16" 192mm) length closed 4 1/2" 115mm) hole diameter 1/2" 13m) blade length (3 1/8 " 79mm) cutting edge (3" 76mm) blade thicknes (5/64" 2m) blade steel - VG-10 weight (2.5 ounces 71grams) handle material - FRN the backlock is positioned midway on the spine and David Boyle Dent is cut from the locking lever. The VG-10 blade has both a hollow grind and a swedge grind with non sharpened spine serrations (jimping) to keep thumb steady while cutting. A black steel pocket clip positions for tip up tip down right hand carry.
39. (N.I.B) Benchmade 440 Opportunist. modified locking liner mechanism, S30v premium stainless steel blade (58-60Rc)Modified wharncliff blade with thumb opener. Anodized 6061-T6 aluminum handle with jig pattern andd stabilized wood scales.
As stated at the beginning I am looking to trade higher more of my knives for fewer knives. I also have custom knives and many higher end peices which could be traded if someone had something on my highly desireable list.
What im looking for is a large frame strider spearpoint digicamo prefferred but regular camo works as well. No customs prefer just a standard model. Any Busse knife. High end fixed blades. A zero tolerance speedsafe with tgerstripe blade, or the new composite blade. A T.O.P.S. Dave Canterbury pathfinder school. T.O.P.S. mil spie 3 or 5. Anything else that may perk my interest open to any reasonable trade offers.
Thanks in advance feel free to email me as it is my easiest contact point ccwow5527@gmail.com
extremely light.
