- Nov 20, 2008
If everything goes the way I've planned, I'll be building my burner today and annealing some spring steel today.
Q1; Most of the forge pictures I've seen have the burner placed at the side, blowing in horizontally or slightly upward, so I assume that is the best position. Is this just for ease of working with the burner or safety of not having hot stuff potentially fall on controls and hoses if it were placed underneath and blowing upward into the forge?
Q2, Does the burner have to be tightly sealed where it enters the forge? The forge will be fire brick so will I be able to just open a gap and stick it in there or should/must I seal it up. If it must be sealed will a wad of fiberglass placed as far as possible from the hot end work?
Q3; Forge or Grind? Obviously, if you use round bar stock, the answer is forge but if you have flat bar stock, say 3/16" do you still forge out your blades or simply grind them and just use the forge to HT?
One more; Does firebrick have a tendency to break at forge temps or is it pretty stable. I'm planning on two pieces of angle iron for the base which will support all of the brick and want to know if this is adviseable or not.
Any answers appreciated and thanks for reading!
