- Apr 26, 2007
I'm getting set up to try forging, but my burner will not light or stay lit for more than a few seconds. The design is based on a few different plans found online. It's built out of mostly 1 1/2" black pipe and uses a ~100 CFM blower. The propane runs through a 0-15 PSI regulator and traverses a brass needle valve prior to entering the burner itself.
I can light the propane when the blower is off, resulting in a billowy orange "eternal flame"-style flame. As soon as I turn the air on, even with the intake of the blower closed off, the flame sputters and dies.
Admittedly, I haven't run the propane at any pressures higher than 10 psi for fear of freezing up the propane tank in the last couple days' 15 degree weather. Is insufficient pressure the likely problem?
