- Dec 2, 2017
Thanks you for the very useful info and tips
Jsega51
and
Horsewright
I worked on a few of my stag handled knives and I am very happy with results.
The steps I took:
Clean knife with soapy water/brush.
Apply PP as described above in this thread until desired color.
Once dry, very gently brush off with a soft toothbrush excess dried out PP if any.
Carefully sand scales until happy with results.
Seal with nitrocellulose (watco, deft etc).
On the fixed blades I taped off the metal and sprayed them two to three times. On the folders I just sprayed lacquer inside a plastic cup for a couple seconds and used it with a little brush to apply the laquer on the folder scales.
I had read on my internet travels that some people advised PP should be neutralized as it may continue to be active and eventually may turn green however other folks disagreed. An experienced knife maker who has been using PP on stag for more than 20 years stated he never witnessed this at all.
On one knife, just as an experiment, I gently wiped the scale with water with a bit of baking soda dissolved in it to "neutralize" the PP.
I really don't think it matters so I only did this with one knife.
You'll see a little bottle of leather dye on the table. I had used it in the past on another knife however it penetrates deeply and when you sand the scales your are not able to obtain the white highspots.
Leather dye is another great way to dye stag however it gives a different look altogether so I did not used it this time.
I stuck with only PP which gives more of that "vintage" stag look.
Before and after side by side:
The steps I took:
