- Mar 12, 2017
Recently got this auto from Boker.
It's designed by Lucas Burnley and made by Protech for Boker
I don't understand how this works, but I'm glad good companies are producing
Burnley designs. This knife was also a good chance to test out Protech knives,
never bought one before and I like the Kwaiken shape.
This is the compact version. They make a little bigger full size version, but I was looking for something in this size and loved the design, so the compact version was a real plus for me.
The knife has what a lot of Protechs seem to have: 154cm, aluminum handle, auto action with with a firing button I see on a lot of Protechs. I like how simple the knife is. The size and simplicity remind me of my Small 21. The neutral handle shape and stonewash finish are nice too. The clip isn't deep carry, but it's what I like where it's as deep as you can go and still have enough knife to grab to get it out of your pocket.
The steel is what you'd expect, a little soft but pretty tough, easy to sharpen, and holds an edge pretty okay. Better than AUS 8 but just shy of VG10. Tougher than both though.
In other words, typical 154 CM but not bad steel especially for every day work tasks.
The auto action is normally strong and locks up solid, but it's like a semi-auto pistol where if you don't hold it tight or properly it misfires and jams or in this case the knife will sort of bounce off the stop pin and not lock. I don't know yet if this is a problem, I'm holding the knife wrong, or the knife needs breaking in. Overall I really like the knife and the non-locking issue seems to get less and close to non-existent the more times I open and close the knife.
The up-swept blade shape may not be the most utilitarian. I normally carry a wharncliffe, hawkbill, or drop point for pure utility, this blade shape easily slides through material because the blade shape causes it to slide out after making an incision. Generally, an american style tanto shape offers me more utility with two flat edges. This could also be a shape I'm still learning to use, you definitely have to roll your hand with the curve of the blade to get the most out of the edge. It does general tasks like opening boxes and cutting string just fine.
This blade shape is my favorite to look at right now, so if it does general cutting tasks good and razor blade type tasks sort of okay, I'll just use the utility razor when needed to carry this "sharp"
looking blade.
I may update this thread if there's interest. I like the knife overall and I'd definitely recommend it for an EDC.
