- Oct 1, 2002
I've got a Burr King 760 and I'm having some problems with the belt tracking. The belt has a "wobble" when it goes around. I set the belt where I want it, but it gives a little jerk to the right as the belt goes around. I've gone through the whole tension arm looking for loose parts. Everything seems solid. I thought the idler wheel bearing could be loose or off center. Seems fine.
I slowed down the belt and stopped it everytime it pulled right. It seems to happen at the same position of the belt, when the seam is on the front platen. I tried a few different belts, ranging from thick 50 grit Norton Hoggers to light-weight Trizac belts, with basically the same results. What's going on?
