BUSCH fixed blade blank
Feedback: +0 / =0 / -0
asking $40 for the first one wharncliff
I am offering a few damascus blade blanks. All the damascus is US made by full time damascus makers. This damascus blank is cut and shaped from a billet Brad Vice of Alabama Damascus made of 4 layers of 5160 and 4 layers of 203e. It is shaped and surface ground to 220 grit, blade bevel flat ground, light etched to show the pattern, NOT HEAT TREATED so can be easily worked, can be heat colored. Add your own scales. Overall length is about 5 7/8" with a 2 1/2 " cutting blade. Since each is hand cut and ground by me the measurements of each will vary slightly. S/H is $5 via USPS priority mail
Asking $ 75 for the second one
This damascus blank is cut and shaped from a billet Brad Vice of Alabama Damascus made of 4 layers of 5160 and 4 layers of 203e. It is shaped and surface ground to 220 grit, heat treated, rockwell 55-58, blade bevel flat ground, etched to show the pattern. Add your own scales sharpen and it is done. Overall length is about 7 7/8" with a 3 1/2 " cutting blade. The item in the picture is the exact one you will receive
